If you have an immediate customer service issue, please visit us at Parts Express
Any suggestions for a better resistor to calibrate the WT3. I would like to use a 0.1% tolerance resistor, I just need to know what ohm value and the source for any recommendations I receive here.
I just went to the local electronics parts place (I live near Birmingham, AL...metro area) and got a 0.1% 1K Ohm resistor. It just improves the degree of precision (supposedly...it's probably more of an OCD thing, though).
Reason: spelling
If you are ordering a 0.1% 1k calibration resistor you might want to also get a few 100 and 20 Ohm pieces for calibration and/or for checking calibration in the lower range. These high accuracy resistors generally reveal the WT3 to be accurate to about 0.1% when calibrated with a 0.1% resistor.
Regards,
John
John L. Murphy
Physicist/Audio Engineer
True Audio
