While I do not necessarily agree all the time with Earl Geddes, I do usually find his posts informative and interesting, so I follow certain threads. I've learned a lot in a number of areas to say the least.
This is another one that struck me, especially since it is counter to so many threads one finds here:
diyAudio thread
The comment that stands out to me is this one in post 578:
Certainly it's not been lost on many here that x-max is not a guarantor of distortion and low-end limits, but there is a lot of emphasis placed on that as well as some other areas that he would eschew. He makes a good case if you follow his posts.
A second point that probably would also raise some eyebrows here (though not mine) is this one:
Treated foam surrounds can be the best solution in some cases and those of SS, for example, are supposed to last 20-30 years. I've got some rather old ones that seem to be in perfect shape.
Non-rubber surrounds are in some situations superior to rubber or other similar synthetics. But with the emphasis on huge x-max and harsh (car) environments, there's a mis-guided emphasis placed on drivers with rubber surrounds at times in gentle environments such as house systems. Interestingly, note that the recent midrange driver from SB Acoustics uses a treated foam surround:
http://www.madisound.com/catalog/pro...oducts_id=8529
Another good example is the venerable SS 21S/8554:
dlr
diyAudio thread
The driver manufacturers obsess over those things that don't matter much, like TS, x-max, Klippel nonlinearity plots, and the like and don't even measure those things that do matter.
This first resonance is critical and IMO the only one that matters. It needs to be as smooth as possible.
In general, a pleated surround with "doping" is the best solution and paper cones are the better damped. The only drivers that I have seen that I find acceptable at these first resonances have paper cones and pleated surrounds with heavy damping. This of course ruins any HF response, but that doesn't matter because I don't use the driver up that high anyways.
dlr
