I have a set of Monitor Audio Radius 225's for fronts, a Radius 180 for a center channel, and the receiver I'm using is a Marantz NR1501. (80% home theater, 20% music)
I was thinking of building a pair of matching subs.
I have an 80 watt/channel AudioSource Amp Two I'm not using for anything else.
The instructions for Marantz said to turn off or set the crossover on the sub amp to it's highest level because it has a built in crossover for the sub output. So I was thinking about running the sub output from the Marantz to the AudioSource to power the two subs.
Here is links to the Monitor Audio and AudioSource specs.
http://www.monitoraudiousa.com/suppo.../specification
http://ec1.images-amazon.com/media/i...L000029636.pdf
Please let me know if this is a waste of time, or a good way to reuse some equipment and not have to buy a plate amp.
This will be my second DIY speaker attempt. The first was 11 years ago; I built a set of 2 way's and a sub from plans designed by a friend. I have no experience with design, just building. Any thoughts and comments about driver size, enclosure type, etc. would be greatly appreciated.
