Well, I finished the Duellati set -- I like them a lot. Also finished the Cerberus subwoofer, so now I'm returning to the NTNs and a second Cerberus I'm building for my brother.
The following photo shows the template and router with bushing installed. I attached two strips of wood on the underneath side to center the template on the baffle. Only the top pattern nearest the router, will be used -- the others were unsuccessful efforts. You'll probably notice the notes written on the template -- that became important so I could tell one from another. Only the last one is usable.
This next photo shows the recess cut with the router. You'll probably notice that it's quite a bit deeper than the thickness of the driver frame. Trim pieces will be overlaid over the driver, and I'll add gasket material under the driver. I may regret saying I'm going to trim the drivers, before I actually get it done. No backing out now...
I scribed a circle to locate the through-hole and then cut withing a quarter inch or so of the line with a sabre saw. I used a spindle sander to sand the holes out to the line. A drum sander in a 3/8 corded electric drill, or better yet a drill press, would also work reasonably well. I used this setup (drum sander in a drill) to sand out the reliefs behind the driver.
In this next view, you'll see the baffles after routing. You'll notice that I've opted to put the ports in the baffle, rather than in the back. I did that solely for appearance sake -- hopefully there's no problem identified with a front port, somewhere in this long thread. I thought about reading everything again, just in case Chris has advised against a front port, but that's a pretty daunting task. In the end, I relied on past advice that the only problem with a front port is the possibility of audible chuffing.
I've mounted ports in several different ways on previous builds. On a number of them, I didn't bother with a flare and extended the PVC completely through the MDF. That provides 3/4" of gluing surface all around the PVC, and plenty of strength. I've also rounded over the ports on several builds, with the PVC extended completely through the MDF. I didn't like having to rout the PVC however, so I've switched to the method you see here. I located the port on the inner surface of the baffle, and drilled a 1/8" hole so I'd be able to locate the port from the outer surface. Then I bored a hole with a Forstner bit, from the inside, that matches the outside dimension of the PVC. I bored to a depth of 1/2" and then glued the PVC in with epoxy. I then made reinforcement rings from scrap MDF to compensate for the lost 1/4" of glue surface area. To complete the port, I flipped them over to the outside (after the epoxy dried, of course) and then enlarged the center hole I bored before, to a size large enough (1/2") to allow inserting a flush-trim bit. I then flush-trimmed the MDF to match the inside dimension of the PVC, 1/4" below the surface. I followed that with a round-over bit to create a modest flare. I'll have more tomorrow.
