Well after playing around with OB midwoofer and 1" domes on scrap MDF, i can honsetly say that i prefer the boxless sound.......profoundly i might add. So with much reserve and not enough $$$, i'm gonna do it anyways!:D
But before i begin, i'd like to have some opinions on the room and placement as even though the junk/test boards gave a very pleasant and spacious presentation, a properly designed point source may be more practical.
I have about 18" of space behind the baffle as free space and the same to the outer walls. Seperation would be about 9ft center to center with an average listening distance of 14ft.
High dynamic range and high efficiency are primary design factors so.......
For bass duties, i simply don't have the space for dipole/OB 15" woofers.....and my room does pretty well with sub 100hz content. First compromise/tradeoff already identified and accepted!
I'd like to use some stuff i already have....namely a pair of RSS315HFs ready for repurposing......as an active bottom end to a 2way OB/dipole top end. Plenty of power on tap for these by way of an NHT B-20 subwoofer amp which currently gives really flat smooth output on the RSS's to the mid twenties. The second order filter goes as high as 240hz need be......in true stereo of course. Figuring on sealed boxes on the bottom and detached from the OB baffle top, i figure on 2.25 cuft volume....Bass response models very well and the current 2cuft sealed arrangement is very smooth in the current position so no worries there.
That being said, for the top end, i'm thinling along the lines of the Deluxe Econowave H0's.....only OB for the 3012HO. Take a look at the open basket on these babies.....
So this is as far as my knowledge of dipoles can take me. Measurements of the 3012 show that we can push it to 1.5kz or so without a problem, but i'm inexperienced on how it will behave OB and just how low it'll go or how low i should take it.
Now the QSC/B&C 250 combo seems like a no brainer here and offsetting the horn for matching the AC to the woofer is a piece of cake. But my biggest concern is the possible 'disconnect' in soundtage from the dipole midbass to the high directivity horn......but maybe with the right slopes and XO point it might just be what i'm looking for.
For Pete S, hopefully this isn't bearing too much resemblance to your steriod powered Orion idea, which BTW is exactly what's fueling this project. You and Zilch have to take some of the blame here with all of the great work done in the Ewave variations.
As does Paul Carmody whose Aethers have been an aching thorn in my side from the first time i saw them......HYbrid is a great thing and will probobly be a large part of the design criteria here as the side panels obviously help with bass extension.
So..please....all of those with knowledge in this area kindly share your thoughts and design philosophies if you wouldn;t mind. Too bad AJINFLA is banned as he certainly has a wealth of knowledge on the subject....and the appropriate amount of sarcasm to share as well.
As always thanx in advance!
