3-way build
  • 3-way build
    i got started on the second floorstander 3-way today. it will have speakers in it by thursday or before. re225-8 x2, silverflute 5.5, north tweeter.
    still tweaking but is close.
    one more layer on this side then i will cut some holes and install the port then the other side top and bottom another 3/8 on the baffle and cut more holes. with a little luck it will look alot like the first one.
    Re: 3-way build
    I wish my cabinetry skills were as good as yours!
      Re: 3-way build
      Nice looking build, that's going to be a pretty speaker for sure.
      If you don't mind, what volume are the woofers sitting in and what frequency are they tuned to?
        Re: 3-way build
        Very Nice!
          Re: 3-way build
          Very beautiful, the sides curve similar to a $20,000 set from Klipsch. Once I convince my wife on some floor standing speakers, I will closely try to duplicate your design. What drivers are you using I"am very interesting in seeing how this project unfolds!
            Re: 3-way build
            Arlis, someday if you want - you can drag one up here and let me practice my measurement skills on it
            Very beautiful, man.
              Re: 3-way build
              ive been hoping you would ask. how about next monday?
                Re: 3-way build
                thanks for the compliments. im not exactly a cabinet builder, i just keep cutting til it fits. :D
                  Re: 3-way build
                  Basically I do the same thing too. Oops! Sometimes the enclosure keeps getting smaller and smaller. Either that or it's down to the Homer D. Poe for another sheet of MDF.
                    Re: 3-way build
                    Amazing. I have the same routers, (big and little) which I use for looks like the same purpose. It sure is easy to trim thin stuff with that little harbor freight hand held trimmer, isn't it? Sure gives a kick when you flip it on, though!
                    Nice work. I was working on a nice set of curved towers before we suddenly moved - similar setup too. It's tough to not be able to do what you love, if only for a year or so. I'll just live vicariously through you for awhile if that's okay.
                    TomZ
                      Re: 3-way build
                      i have seen your work tom, and its pretty good. my ryobi routers have served me well. the hf trim router works well for simpler tasks.
                      more tomarrow.
                        Re: 3-way build
                        I'm not that confident yet, Arlis. Give me another month. I hope to have repeatable data by then. Right now, I still have weird things showing up
                          Re: 3-way build
                          its cool brother. but, i WILL continue to hound you if you dont mind i cant imagine what but let me know if i can help in any way. i do stop at pe about every three weeks or so if you need somthing small.
                            Re: 3-way build
                            this started off as a three driver speaker. upon testing the lows were overwhelmed by the rest so i added another 3/8 mdf moved the woofer up a little and added a second. as it turns out, the little 15x2 t-amp was not up to the task. i now have a sure 100x2 amp to test and tweak with. i listened for about an hour before the mushroom cloud appeared and they sound really good. so i will build the other. i have two used and two new rs225. one of each is intalled in each enclosure. seems to sound the same with the vent open vs rolled up pair of socks tightly stuffed in. lower has wafflecone packing foam and the top will have accustastuff.
                            25"x11"front tapered to 6" in the back by 12.5 deep. im guessing around 30L
                            2.5x12 rear port. fb 30hz
                            f3 40
                            f6 34
                            f10 28
                            two rs225-8 8" woofers
                            one silverflute w14rc25-08 5.5" woofer as midrange.
                            nla north 13w-06s19w tweeter
                              Re: 3-way build
                              Very nice looking speaker, Arlis! I hope to hear them at Iowa this year.
                              Dan N.
