I have a pair (Ser# 1,2), and they were discounted nicely at the TS, so here's what I get:
I remind you that they are 2" drivers, 3mm Xmax, and 4 ohm impedance. That means they hit about 81-82dB as a 2.83V spec. They are basically all magnet mass, 'cuz the frames are plastic, the paper cone is covered by an aluminum dustcap, and the half-surround rule only nets you about 13cm^2 of Sd. However- that Bl value is pretty high for a 2" driver. The dustcap sits inside the former for attachment, and a small lip is left around the perimeter that might act as a slight whizzer. It's hard to tell if it will have an affect on FR without measuring it. The spider is vented, but the pole is not. Looks like a periphery venting system. The spider is of the progressive variety, and only has 2 large rolls in it. VC is 'hung well' for a 2" driver, and I can see at least 3mm above the front plate. Former is probably cardboard like most of TB's smaller drivers.
I also have a double of the 3" Titanium PR's to try with these, so we'll see what I come up with....
I expect that these may have some 'slam', but not much extension. More of an impact-driver.
More later,
More later,
