Re: New FAQ - How to design without measurement gear
Yes, I use all 3 for different things and Hornresp and MJK's MLTL worksheet are both easier to use than WinISD alpha. The first big thing you will notice is the ease of entry of t/s parameters in both programs I mentioned. In WinISD it's a somewhat tedious and lengthy process in which you have to open the database editor, enter parameters in a specific order, and hope the t/s parameters are correct, or WinISD might not accept them at all. Both of the other programs make t/s entries extremely quick and easy.
Moving on, Hornresp's relatively new slider controlled Loudspeaker Wizard makes the actual design process incredibly - almost ridiculously - fast and easy. OTOH, MJK's MLTL worksheet does not necessarily make the design process faster than WinISD but it's certainly no harder to use than WinISD.
And both programs are far more accurate than WinISD - and that's really the only thing that really matters, isn't it?
As for choosing between Hornresp and MJK's MLTL worksheet, Hornresp is much faster and easier to use but it cannot simulate the effects of stuffing (or lining) and can't calculate port velocity, while MJK's software (Mathcad) interface is a bit more cumbersome but it can simulate stuffing and port velocity. Hornresp is free and MJK's software is not.
If you have never tried Hornresp - and particularly the new(ish) Loudspeaker Wizard, I would strongly recommend it. It truly is faster, easier, and far more accurate than WinISD. And it's free too, so it won't cost anything but a bit of your time. Hornresp can now be found at http://www.hornresp.net.ms/, try it, you might like it.
Originally posted by fastbike1
View Post
