Re: Peerless 6 woofer 3-way under way
I have been studying a lot of DIY designs since I started coming here. This design using the 4 woofers in series/parallel looks like what I want to build.
I have a couple of questions about what I want to do related to Pete's build:
Would there be any advantage to rolling off two of the bottom woofers like in the Elsinore build? Maybe bumping the cross to the mid a little higher. I have a pair of Peerless 832873 I want to use for the mids. This relates to why I thought bumping the cross to the mids might help with male vocals/lower mid range.
What are your thoughts on box volume for the 4 woofers is appropriate? My first attempt with UniBox showed just over 2 cubic feet, the Elsinore has 2.7 and the port values are different there also. Almost 4" x 12" for UniBox and like 3.4" by 3.5" for the Elsinore.
I am considering the Vifa XT25TG30-04 set in a shallow wave guide for the tweeters. Seems like it would help with the depth/timing in relation to the other speakers, so any input here is helpful.
Ok so I am probably messing up my UniBox attempt some where and I am comparing apples to oranges. So any input, positive or negative is appreciated!
Thanks!
David
Thanks!
David
