Contimuum TL Done!
  • Contimuum TL Done!
    Thanks to Jeff Bagby for kindly allowing me to experiment with his design. This is basically a Continuum baffle placed in a TL enclosure. The AC130/F1 does well in a TL as we know from the TzuJan's (Paul K's TL on the TzuJan's BTW). Jeff's Continuum is as nicely executed 2-way as I've heard. A match made in DIY heaven as it were.
    Enjoy. Well, actually, I'll enjoy.
    Full length:
    Baffle:
    Inside woofer press fit mounting:
    Re: Contimuum TL Done!
    ANOTHER flawless looking speaker. Amazing.
      Wow. Beautiful work. If you care to send a picture, I will gladly add it to my gallery.
      Martin
      Quarter Wavelength Loudspeaker Design
      www.quarter-wave.com
        Wow Maynard, another excellent build!
        And BTW 'he' never asked to add the Copper Project to his gallery.....MRS. OLSEN!!! He hates my coffee!!!
        :D
        Marty
          Just curious. I know the Continuum design relied on a "bump" in the bass response due to alignment, to aid in compensating for baffle step, among other benefits. Moving the bass cutoff with the TL should have had an impact on the overall voicing. Were any other mods to the XO applied to accommodate that change?
            Not yet, Pete. Sounds awfully good as is. Gotta get some hours on the woofers, then I'll do some direct comparisons with the TzuJan's and some measurements.
              Are you hearing significant bass extension with the TL versus the closed small box?
                Can't say with certainty. I don't have the original to compare with.
                  I would expect so. ;)
                  Do you remember hearing the TzuJan's in Ft. Wayne, Darren? Very impressive bass for a small speaker with a 5" woofer. That's why I was interested in trying this combination of Maynard's TzuJan and my continuum out when he approached my with the idea.
                  Although, I do believe there is a trade off in power handling. The small sealed box of the Continuum will control excursions very well on the AC130, allowing it to be driven fairly hard before we see/hear some real stress. I am concerned that this will occur at a much lower level with the MLTL design. But, the TzuJan's had very nice bass, and I love the mids and highs in my Continuums - I would expect this to be an excellent small footprint speaker.
                  Maybe there's a future for it out there somewhere. :D
                  Jeff
                    T/S parameters predict the AC130 will have an F3 of about 70Hz in the Continuum. Close-mic'd measurements in-room indicate about 65Hz, and it is already rolling off at 12dB/oct. I am sure you are getting more extension than that with the larger box and the MLTL tuning.
                    By the way, when Paul did the MLTL simulations did he use the advertised T/S parameters for the woofer, because the real ones are quite different than Aurum Cantus' published specs? I can post what I measured, but Zaph's measurements were essentially identical. My Fs was little lower, about 49Hz, but I broke the drivers in first.
                    Jeff
                      Pete, I believe with the changing of the frequency of the impedance peak there is a resulting smoothing of the bump in the upper bass when it is placed in the MLTL. I think Maynard's bass will be smoother and more extended. I would prefer flatter if more extension is available too.
                        He used T/S taken by me using WT3.
                        AC130/F1, after break in, tested by WT3
                        f(s) = 50.47
                        Q(ms) = 4.442
                        Q(es) = .578
                        Q(ts) = .511
                        V(as) = 14.42 l
                        n(0) = .31%
                        M(ms) = 7.83g
                        R(e) = 7.73 ohms
                        Z(max) 67.13
                        L(e) = .6 mH
                        C(ms)= 1.2 mm/N
                        BL = 5.76
                        SPL 86.95Db
                        Jeff
                          Maynard,
                          The speakers looks very nice. I hope you show it at Indiana next year.
                          Darren
                            Jeff
                            Yes Jeff. I certainly remember the TzuJan's. I thought they were amazing pair of loudspeakers. They certainly filled the room as well. I definitely think there would be a future for a Continuum version.
                            What about a three way Continuum similar to what Dennirs Murphy did to his MB0W1s.
                            Darren
                              f(s) = 50.47
                              Q(ms) = 4.442
                              Q(es) = .578
                              Q(ts) = .511
                              V(as) = 14.42 l
                              n(0) = .31%
                              M(ms) = 7.83g
                              R(e) = 7.73 ohms
                              Z(max) 67.13
                              L(e) = .6 mH
                              C(ms)= 1.2 mm/N
                              BL = 5.76
                              SPL 86.95Db
                              Yes. Those are very consistent with mine and Zaph's as well. It's too bad Aurum Cantus and PE don't show parameters that are closer to reality, especially since the drivers are very consistent - just different than advertised.
