I've read a fair amount of promotional material (possibly hype?) decrying the benefits of mounting woofers opposite one another to achieve an alleged "force cancelling effect". Has anyone actually built something like this and measured the difference in cabinet vibrations with an accelerometer between running the woofers in such a configuration in phase (opposing directions) and reversed phase (woofers travelling in the same direction)? Given the physics involved in suspending woofers with a fixed connection (KEF Uni-Q) or not - it seems to me that the more important forces making the cabinet vibrate are ultimately the small changes in pressure or pressure waves travelling through the cabinet - not the transmission of force from the moving diaphragm assembly to the baffle through the basket mounting surface. It would seem to me - especially if you were able to install bracing from one driver to the other - that operating the woofers out of phase (acting somewhat like a passive radiator/woofer pair would) would minimize the pressure fluctuations in the cabinet and thus reduce mechanical enclosure resonances throughout the enclosure structure - not simply in the vicinity of the basket mounting area. Does this make sense and if so, why isn't the out of phase connection setup considered the defacto "standard" instead of the in phase connection? Lynn Olson apparently has a design using this "force cancellation" method although I haven't had a chance to read up on it as yet.
Most of my enclosures have used solid veneer core plywood with MDF inner and outer skins and elastomeric adhesives between the layers. This has been very effective in silencing cabinet vibrations but obviously, particularly with triple layer construction, gets quite heavy. So, before I take the time to experiment with Isobaric or push/pull configurations, I was wondering if anyone has tried different setups and compared the results.
