Flat Response
  • Re: Flat Response
    Is this the point where we're all supposed to put our fingers in our ears and sing "la la la la la la la la la la la "?
    :D
    • Re: Flat Response
      DDF - I applaud your patience. You have brought a lot to this discussion. AJ, in a strange way you challenge us...
      I think the problem with this type of philosophical discussion is the explosion of different concepts. When we attempt to address one, the subject changes ad infintium.
      Perhaps it is best to create new threads to address the applied science and or specific concepts from this thread.
      • Re: Flat Response
        Originally posted by auracle View Post
        is This The Point Where We're All Supposed To Put Our Fingers In Our Ears And Sing "la La La La La La La La La La La "?
        :d
        Lol!!
        • Re: Flat Response
          Originally posted by dlr View Post
          Consider what you're asking. A complete response would require a book or an entire volume that does not yet exist, since the "recommendation" would have to address specifics. How many variables exist between drivers/system/room/preferences and more to the point, what are they precisely?
          EXACTLY!
          There IS no answer short of a comprehensive analysis of the specific situation encompassing at least the major variables, with understanding of how they might interact in that particular circumstance and knowledge of what to do to produce the optimum result based upon that information.
          Originally posted by DDF View Post
          It seems in your view there is only one narrowly defined set of trade offs and design direction.
          There is a recommendable direction with a reasonable likelihood of producing a worthwhile outcome, well founded in credible research, which is compatible with the skill set and experience level of the majority of DIYers.
          You seem to think I think that flat response with well controlled power is not a valid approach, and so exclude me from your list. Why? I've never once stated that.
          I am duly pleased.
          Start flat, and tune by listening and measurement from there, to sound most accurate and best in your room and listening location.
          We agree, but kindly allow that I said it first:
          Originally posted by Zilch View Post
          Without that knowledge, the most rational course is designing to the established baseline reference and adjusting from there, as required or desired....
          :p
          • Re: Flat Response
            EXACTLY!
            There is a recommendable direction with a reasonable likelihood of producing a worthwhile outcome, well founded in credible research, with is compatible with the skill set and experience level of the majority of DIYers.
            I am duly pleased.
            We agree, but please allow that I said it first:
            :p
            I'm glad we seem to agree, but in my first post I said:
            "Very often, getting a nice flat line on axis requires launching a poorly balanced sound into the room at other angles. The smaller and livelier your room, and the more noticeable this will be as a tonal imbalance"
            Key words: very often.
            We just spent the next 15 pages dancing until your reading comprehension caught up.
            • Re: Flat Response
              I AM lazy, remember.... ;)
              • Re: Flat Response
                So fix the other angles via design. Like Harman. Like Geddes. Like Genelec.....etc., etc., etc.
                Produce a cure, not just take aspirin for the symptoms.
                And how often can the fixed filter elixir cure all variables after the "your" room TF - like recording HF variability, moving to another space, personal taste, etc, etc, etc.
                Oh yeah....not very often.
                "Fixed"...not "variable". Key words .
                • Re: Flat Response
                  Yeah...I wish this post could play the tune along with the image...
                  I had to, because this thread is out of control...
                  • Re: Flat Response
                    E.g.:
                    Originally posted by Toole, p.376
                    If equalization is used to flatten the room curve, the pristine on-axis curve will be lost -- the only thing that was correct about the loudspeaker. An equalizer changes frequency response, not directivity. The cure for this room curve is a better loudspeaker, one with better directional consistency.
                    • Re: Flat Response
                      ---clip----
                      Dan: to answer your question, experience, common sense (ie you honestly don't think the same speaker will have different tonal balance in different rooms?). Secondly, even Toole agrees. Why did you ignore what I wrote where Toole says that a first reflection, if over absorbed in the treble, will make the system sound dull?----clip----
                      My point was you time and time again make points that are unchallenged and also unsupported. You're wanting to call many years of research 1 study. You know I have the same 2 pairs of speakers in 2 different room--one treated, one not. I know from experience that they difference is not that big. I don't care to discuss all the extremes that people go through to screw up their sound, but in a fairly normal set up, a speaker that measures well by the known "good sound" metrics will sound darned good. Yes you can probably better it with treatments and maybe changing the speaker, but I don't even care to guess at present.
                      I guess I just haven't seen a room problem bad enough to try and modify the speaker to fix. YMMV. No hard feelings. I think you've had some great ideas and stated them well. Sorry that hasn't come through in my posts. I did try and wasn't thinking about you or your thoughts at all in the post you totally disagreed with.
                      Dan
                      "guitar polygamy is a satisfying and socially acceptable alternative lifestyle."~Tony Woolley
                      http://dtmblabber.blogspot.com/
                      http://soundcloud.com/dantheman-10
                      • Re: Flat Response
                        I just saved money on car insurance.
                        This was unexpected.
                        I am trolling you.
                        • Re: Flat Response
                          Originally posted by dantheman View Post
                          SpacePatrolman, thanks for the links.
                          No problem.
                          I actually do this: If I'm working on a project w/ a friend and I screw some little things up, I'll give him a low bitrate mp3 to use for practice and it will hide small errors of various natures even clipping.:o Shameful I know, but sometimes I figure things out too long after I recorded them to do much about it really other than hide it.
                          :eek: Forty lashes with some wet organic pasta. :D
                          Hey it's just for practice purposes, so why not.
                          Our brains do seem to fill in some of what's missing, but it's no substitute for the real deal.
                          And the reason why so many people can still enjoy their music using an AM radio with a 3" paper speaker (amplitude modulation? man does that date me! ).
                          I'm not going to pretend to understand everything written here but I am really surprised the room+speaker interaction issue wasn't solved a long time ago. It just seems so....basic.
                          But maybe the speaker manufacturers aren't in much of a hurry because even in the olden days the engineers, before all the various driver/enclosure/etc operating parameters we presently use were discovered and taken advantage of, along with basic electrical/sound concepts simply relied on their own hearing systems and trial & error to make their speakers sound "right". And as a result, many of those systems (if properly maintained or brought back up to their original specs) still sound amazingly good. I don't mean "for their time", I mean they just sound good.
                          Humans were putting together some pretty darn good gizmos and widgets long before computers came along, so personally I wouldn't dismiss everything that was built before those binary-based devices came along.
                          Concert hall realism: I also believe a multichannel format, properly configured on the recording and playback ends, is about the only way to TRULY recreate (within practical limits) what was heard at the performance venue. There is just no way for a pair of speakers in front of the listener to properly recreate reverb effects that originally emanated from behind the audience at the venue.
                          Though speaker systems that add front reverb(?) via rear or side-facing drivers can IMO definitely help create a sense of air and naturalness to a recording though I think with some music genres, like punk or metal, this may not always be a good match. There were many respectable companies that sold such systems in the 60s and 70s but I have a feeling a significant part of the reason for their small numbers nowadays is not so much most people felt they sounded bad, but because such speakers need to be placed so carefully in a room for all their drivers to do what they were designed to do. Extreme examples of this would be the Bose 901 and Sonab OA-116.
                          BTW here's one recording engineer's solution for capturing concert hall ambience in multichannel form: http://www.isomike.com/
