Building speakers almost by ear?
  • Building speakers almost by ear?
    I don't have test equipment, but I do have access to the usual online programs to help me design, or at least maximize the design.
    The only test equipment I have is a signal generator that is not geared for the accuracy of frequency testing, an ocilloscope and other tools to repair stereos in my spare time.
    I have been DIYing speakers for years but honestly -I'm just fooling around with these compared to you guys.
    I'm working off two basic plans. One was from a monitor and the other from a three way. There is only one driver that is not common to both - the midrange. I am substituting in place of a Seas H1262 5.5" for a Vifa P17WJ-00-08. Simply because I can't afford the extra parts and driver right now.
    With out the aid of more advanced programs and audio test equipment, how can I test by ear the results. Or what should I be listening for?
    I've listened to the mid/tweeter for days and it seems to be right. But I have no idea how it will sound when I throw the woofer and it's crossover into the mix. The reason I'm hesitant is because I have to build a bigger box to try it!
    Re: Building speakers almost by ear?
    Why not tell us more? What drivers exactly? You can model the box with WinISD, can't you?
      See if this helps.
        I am not sure about the OP but it sure helped me! Thanks!
          It can be done and well. Maynard's Tzu-Jan's won at Dayton a couple of years ago! Wolf has an extensive writeup about using the tools to produce great results w/o measuring.
            Free support for loudspeaker projects, sourcing OEM speaker building supplies, and passive crossover design. We sell raw speaker drivers (tweeters, woofers, subwoofer, midrange drivers, full range drivers), speaker kits, amplifiers, capacitors, resistors, and inductors.
            Here are the drivers. I plan on crossing them over at around 250-275Hz and 3000-3200Khz.
            In a 2-2.25 cf bass box and seperate 0.15-0.2cu vented boxes. The vifa sounds better vented. Sealed it really sounds muted.
            I will draw out my present crossover later and scan it. It comes from two different schematics, then tweaked.
            charles
              I had to put this on a second post due to uploading problems.
              I'm using this for the mid/tweeter. the substitutions I made were:
              1.0mH coil in place of the 0.9 on woofer
              3.3uf cap in place of the 5uf on tweeter
              2ohm resistor in place of a 3ohm on tweeter
              0.39mH coil in place of the 0.5mh on tweeter
              Replaced the Vida tweeter for the Seas 27TDFC
              It seems to works very well in a 0.3cu vented box.
              I needed to add in the 250hz xover. I'll draw that out later.
              charels
                woofer xover
                I plan on just trying a simple 80uf cap on the mid to start.
                charles
                  When I was still building speakers - I did the tuning entirely by ear using a graphic equalizer and extrapolating the crossover values from the resulting curve. It usually resulted in a large crossover with a lot of parts - but sounded very, very good.
                  Recently, I sold a pair of speakers that I designed, called the Wonder Bread Towers. They won 2nd place (IIRC) at some DIY event in 2001(?). The new owner likes completely different (and much louder) music than I, but has never been disappointed with them.
                  So yes, it can not only be done - it can be done exceptionally well.
                    woofer xover
                    charles
                    I simmed your XO with your drivers, except I swapped in an 831727 for the 850146, and an MG17SG09-08 for your P17WJ.
                    It doesn't look horrible. It wanders down about 5 dB from 200 Hz up to around 1kHz, where it looks pretty flat up to around 6kHz, then rises about +3dB by 12k or so.
                    Cross points are as expected, and I wired both the mid and tweeter with reverse polarity.
                    Chris
                      Why waste time and money by not using measurement? I remember the frustrating times in the '70s when all I had was Radio Shack drivers and my ears. It resulted in a lot of money wasted. As you mention there are programs on the 'net and a mic is about all you need to buy apart from drivers and components. Like they say in carpentry, measure twice, cut (re. wire) once. Electronic/DSP crossovers simplify things quite a bit, apart from the complex wiring of amps to speakers.
                        This thread should be in the main forum. Finished projects are the intended use of this forum space . . . ;)
                          +100. It seems at least half the threads here shouldn't be.
                          www.billfitzmaurice.com
                            If that is the case, why are answers provided and the discussions is continued by 'senior members"? How about a respectful comment that this forum is for COMPLETED speaker projects, not a Q/A forum and please move it to the main forum. On the other hand, posters apparently do not read the title of this forum. Go figure.
                            Now, off of the soapbox.
                            George
                            "In order to really enjoy a dog, one doesn't merely try to train him to be semi-human. The point of it is to open oneself to the possibility of becoming partly a dog." - Edward Hoagland
                              George
                              You know what guys? Every day (hopefully NOT every hour?) when I come in here, I log in to techtalk.parts-express.com, then hit the "New Posts" button.
                              All new entries from ALL the forums pop up comingled in a list. I just pick and choose the ones I'm interested in, opening each one in a new tab. I'm not really even aware of WHICH FORUM I'm reading or responding to.
                              If I feel like starting something new, I do. I don't really even bother to check where I'm at. Sorry, but that's how it works for me. Maybe a lot of others navigate in here the same way?
                              Chris
