Finally took the plunge when Rockler blew out their 24 X 24 PSA veneers for $12.50. By the time I got there, the selection was down to White Birch or Red Oak. Red Oak was the choice. Application was very easy, trimming not so easy. As others have noted, edge seams can be difficult to keep the line from showing. It did not come out too bad, as I got better with each seam. The finish is one coat of Minwax Wood Conditioner and one coat of Minwax Driftwood stain, wiped off after 3 minutes. I have not decided on a semi-gloss/ satin top coat yet - we will be warm enough tomorrow to apply, so any suggestions would be appreciated.
First Try at Veneer
Re: First Try at Veneer
Looks very flat... nice job. Odd...you said the application was easy but the trimming was not. usually it is the opposite...Laying it flat has always been the trick for me...
If you use raw veneer you wont get the line showing...
Originally posted by mgrabow View PostLooks very flat... nice job. Odd...you said the application was easy but the trimming was not. usually it is the opposite...Laying it flat has always been the trick for me...
If you use raw veneer you wont get the line showing...Audiophiles listen to the equipment, not the music.
Very professional....
