FRD and ZMA request for Peerless 830883 and Usher 9950
  • FRD and ZMA request for Peerless 830883 and Usher 9950
    Before I make a second attempt on these, do any of you already have FRD/ZMA files on the Peerless Exclusive 830883 7" and/or Usher 9950 tweeter? Thanks in advance!
    -Steve
    Re: FRD and ZMA request for Peerless 830883 and Usher 9950
    -Steve
    Merry Christmas.
    Ho
    Ho
    Ho.
    Traced from Zaph, no diffraction added. Impedance files were traced. Should probably be modified with response modeler.
      Merry Christmas.
      Ho
      Ho
      Ho.
      :eek:
      Pete, you are the man!
      Thanks bud !
        Total zombie, I know. Bit my search for 830883 .FRD .ZMA led me here. COVID gave me an opportunity to dip my toes into XSim (finally) and I have a pair of these HDS exclusives and RS28F (NLA) on the shelf so I thought I would see what I might concoct. But, the files Pete posted (thanks Pete, hope all is well w/ you) do not work for me. I opened as text file, and the values don’t make sense to me either. Any chance one of you XSim pros take a look and see if they look weird or work? Thanks for the hand. Tom
        • Geoff Millar
          Geoff Millar commented
          Editing a comment
          I think there's a project using those drivers by 'Navy Guy' of this Forum; I can't recall its name but it was a floor standing speaker with a stunning finish which looked like a Gibson Les Paul.
          http://projectgallery.parts-express....the-standards/
          Edit: these use the RS28A, but might be useful anyway
          Geoff
        Hi Tom,
        Files look ok to me. You need to open each one of them as a text file with something like Notepad, then File > Save As > then remove the .txt on the end. So 830883.frd.txt becomes 830883.frd and so on. I was able to import those files into XSim and they work as expected.
        Craig
        I drive way too fast to worry about cholesterol.
          If you don't like the file renaming process: You can see all file types if you first type "*.*" in the XSim "File name" box and follow it with a carriage return (i.e. the Enter key). Then select the file you want.
          "Everything is nothing without a high sound quality." (Sure Electronics)
            Hi Geoff. I remember Kerry’s (Navy Guy) “Standards” I will certainly revisit that. And thanks PWR and ern, I will rename the files and try to re load.
              Thanks again all. renaming the files did the trick. The curve for the 830883 looks just like Zaph's, so was probably a trace, that's ok. Off and running :-)
                I'd suggest running the .frd files through Jeff's Response Modeler to add the effects of baffle step loss and diffration, then extract minimum phase. Unless of course these will be an in-wall design.
                Craig
                  Thanks Craig. Yes, response modeler will be my next try. I may have to just bite the bullet and get a measurement rig and software to measure drivers on baffle and export my own files, like the big boys do. 😉
                    RS 28 F nude.frd RS28 F.txt hope this helps
