Build Thread: SR71-inspired Center Channel
  • mzisserson
    Re: Build Thread: SR71-inspired Center Channel
    Looking great man! Cannot wait to hear it!
  • lunchmoney
    Originally posted by captainobvious99 View Post
    Excellent looking work! How will you finish the center channel?
    Thanks
    Normally I would paint it, but I'll probably just use some PE "black ash" vinyl laminate that I have left over. Because it will be buried in the AV cabinet, and have a grill on it, you'll never really see it.
  • 1100xxben
    Originally posted by lunchmoney View Post
    Clever! But it would seriously complicate the mounting of the baffle on the mill, because of the thickness of the tweeter.
    The 4 bolts hold the tweeter together. If you remove them, then you can separate it and mount JUST the faceplate, as I did in my picture. I'd never mount a full tweeter in a baffle and start cutting, as it'd gather all sorts of junk.
  • captainobvious99
  • lunchmoney
    Here's a tip for you. The next time you want to trim a tweeter faceplate, cutout the tweeter mounting hole first and mount just the faceplate on your baffle. Then, when you cut the recess for the woofer, you will also cut the tweeter faceplate with a perfect finish! Attached is one that I did with my router. You could even do metal faceplates with your mill.
  • 1100xxben
  • lunchmoney
    Here's a step I really should have done BEFORE gluing on the baffle... drilling the holes for the grill magnets with a forstener bit. This was a pain.
    Driver holes covered with duct tape... ready for sanding...
  • lunchmoney
    Here I trimmed the tweeter flange with a dremel tool...
    Then I cut out notches for the tweeter terminals, again with the dremel tool...
    Drilling the pilot holes...
    Now, finally, my favorite part: dry fitting the drivers. I've never done a trimmed flange before, so seeing this come out well was a big relief...
    I use this opportunity to mark the location of pilot holes for the screws. I'm done with h-nuts. Had one spin on me recently. Using plain old black wood screws this time...
    Pilot hole locations marked...
    Time to glue the baffle on. One trick I like is to start with just two clamps... lightly tightened, but still loose enough so that I can slide the piece around until it's exactly where I want it...
    Then I tighten those two clamps, and add a bunch more, paying particular attention to where the braces are...
  • lunchmoney
    Originally posted by andykriech View Post
    Lunch,
    Quick question on your porting.
    With the rear port and the HT/equipment table you linked at the beginning having a closed back, will you be opening the cabinet back to allow the port output out?
    Otherwise, it would seem to need to be front ported or will the center channel be placed on top of the cabinet?
    Andy.
    The back of the shelf is not sealed... there's a substantial gap for running wires, etc.
  • andykriech
    Lunch,
    Andy.
  • lunchmoney
    Originally posted by jclin4 View Post
    Beautious! I have to say, Lunch, I find your build threads incredibly well documented and I learn alot from them, with or without videos.
    Great! That's very nice to hear, as I really enjoy creating the build threads.
  • jclin4
  • lunchmoney
    Originally posted by greywarden View Post
    Awesome, totally dig your paint jobs
    Thanks. This speaker will be decidedly less interesting to look at, as it will be buried in the AV cabinet and have a grill over it for baby-proofing reasons.
  • greywarden
  • lunchmoney
    Is this going to match the ones in your avatar??
    Nope, those are Tritrixes
    It's going to match these, my SR71's (I built these as well)
