Statements question
  • Statements question
    I have acquired a pair of already built enclosures that a friend of mine was going to use for something he has forgotten now . . . they have been sitting in his garage for a few years now. External dims are 47" by 11" by 14" (HWD) and are build using 3/4" MDF sides and back and a 1" thick hardwood removable baffle. No braces have been installed (yet . . . easy to do with the removable front) and internal volume comes to 88.5 liters (3.125^3ft).
    Could these enclosures be modified into a pair of full size statements? Curt suggests on his site that with the new non-shielded drivers, a volume of 80 liters should be used rather than the original 100 liters required for the older drivers. When taking out the volume required for the mids I think I'm getting pretty close. I would of course want to add bracing.
    Secondly, I would want to build these as a MTMWW rather than a WMTMW in order to keep the tweeter more at ear level. Would this be a bad move or should I just stick with the original config and build some stands?
    If this is all around a bad idea, what other suggestions do you have for these enclosures?
    Re: Statements question
    There are a couple of things I think you'll have a problem with. The actual net volume of the cabinet after subtracting the volume for the two mid tunnels, bracing and volume the drivers themselves take up, I think you'll be closer to 70 liters net for the woofers. This is still doable with port length adjustment.
    I think the real show stopper is rearranging the drivers. I'd suggest you consider the RS 3-way as an alternative. I've built it and its a very nice design that sounds great. There are a number of crossovers available but Dennis Murphy's crossover was the one that was built and developed on actual speakers.
    It should fit your needs well.
    Jim
      What are the optimal foam/dampening materials for both the main enclosure and the mid tunnels?
