What if Tony Gee's "Black Box" were done as larger towers?
  • What if Tony Gee's "Black Box" were done as larger towers?
    Here's the speaker I'm talking about:
    Very high quality loudspeaker kits, components, upgrades, modifications and custom solutions. Humble Homemade Hifi - the one stop loudspeaker shop.
    If I wanted to make them as floor standing towers, with a larger woofer enclosure volume, would it be easy to figure out? Major changes to the crossover?
    I could just build them as is, but I remember some comments a while back to the effect of "why not just make them bigger?"
    Thanks
    EDIT:
    Let me back up and explain how I got to this:
    I've got a pair of the 10" RS Woofers (like those in the Black Box), and I'm itching to build a pair of big(ish) 3-ways.
    The Black Box is the only 3-way I've seen that uses 1 per speaker (there is a gigantic 3-way TMWW on HT guide that uses two per, but that's just way too big)
    Anyone know of other 3-ways out there that use them?
    Re: What if Tony Gee's "Black Box" were done as larger towers?
    IMO if it were done as larger towers it would be a dramatically better design. (I'm not a fan of that design at all - the compromises he chose make absolutely no sense to me.)
    Yes, the crossover would need to be changed, just off the top of my head, the larger towers would not require the passive assist. And the baffle dimensions would obviously be different, which may require other xo tweaks as well.
    Might be best to start from scratch.
    Don't even try
    to sort out the lies
    it's worse to try to understand.
      Well, I certainly wouldn't worry about giving [the RS270] it too much volume, particularly if you switched to ported - you'll be able to take measurements after you build it? Plenty of us are willing to help with crossovers, if there are good measurements.
      I see no need to "start from scratch" if you like the design and basically just want tower versions. Also, a high pass/"passive assist" is generally a good idea but not implemented as a cost comprimise (or simply because the designer isn't aware of the benefits).
        See my "Edit" above in the original post.
          Indeed, making them bigger will work just fine. No need for all that capacitance, either.
          I am trolling you.
            Now if only I had any clue how to modify the x-overs.
              A change in the bass response will indeed require modification of the mid/woofer XO. Simulations should be adequate, as all drivers used have been extensively tested.
              Trace them and pop them into PCD, and then go to town. Be interesting to see how his XOs match up to available measurements and simulation.
              I am trolling you.
                Which may also lead to modification to the M/T XO if there is a change to overall system efficiency.
                http://www.diy-ny.com/
                  Start with something like the Dreydel, and then use the RS270 as a bass bin, with simple capacitive highpass on the TM.
                  Tony's design relies heavily on the boost design to arrive at the correct voicing. Changing the woofer alignment will certainly change the midbass performance. And the fix is likely a bit more complex than simply changing the padding on the mid and tweet.
                    I'd like to build those, but they have a $1200 BoM and that's with 100v NPE's for the (4) 160uF caps.
                    रेतुर्न तो थे स्रोत
                    return to the source
                    leviathan system thread
                    deadhorse thread
                    shockwave build thread
                    instagram :: greywarden_13
                      I really like how he left the compartment open in the back to see the crossover
                      My projects
                      https://picasaweb.google.com/112307725038877176664
                        This is actually the biggest reason I don't like this design. It's clearly a matter of preference (some people like it and some don't) but personally I can't imagine why he would waste a full 1/3 of the available box volume and then use capacitance to bring the response back in line. This makes no sense to me whatsoever.
                        And that's the second reason I don't like the design. You could do a whole lot better for less than half that price using the same drivers (IMO of course). But I suppose boutique parts are a matter of preference just like frivolous contouring filters.
                        Tony is clearly a bright guy and he does good and competent work but our design philosophies are on opposite ends of the spectrum.
                        Don't even try
