Cabinet / Baffle CNC Service
  • #16
    Re: Cabinet / Baffle CNC Service
    so, if you can draw it, you can cut it? those braces are wicked.
    • #17
      Does this price include roundovers?
      • #18
        Basically, yes. There are a couple of limitations, but if I can draw it, I can cut it. For example: I typically use a 1/4" end mill, so any inside corners have to have at least a 1/8" radius. Also, super intricate design with thin sections are prone to breaking out, although I doubt any speaker cabinets would have this issue.
        Thanks for the compliment on the braces. I spent a couple of hours last night laying those out...
        • #19
          No, but I can for a little extra.
          My thought was that it would be best to do the round overs after the cabinet is constructed to account for any misalignment during construction.
          • #20
            Do your panels incorporate rabbet joints or just bu++ joints? What is your preferred format for information transfer for custom cabinets - drawings, written description, CAD, etc.?
            Dan
            _____________________________
            Tall Boys
            NRNP Computer Sub
            The Boxers
            The Hurricanes
            The Baronettes
            Conneccentric
            UX3
            • #21
              Dan,
              THe cabinets I've been describing use regular bu++ joints. I can do rabbets. I built the cabinets for my ZA5.2's like that. Although I'm not sure it's worth the effort. I don't plan to do it for anything else I build for myself. I think good quality glue along with a brad-nailer is just as fast and strong. It also keeps the cost down since there is less machine time.
              I can pretty much handle the design however you want. However if I had my preference CAD drawings would be first, followed by a sketch with dimensions on it, and then a written description. It seems that the more specific things are the less opportunity for errors in translation there are. This goes for more than speaker cabinets...
              Dan
              • #22
                Hmm. How about finger joints?
                Also, can you take payment in the form of speaker parts? Goodness knows I have too many. :P
                • #23
                  Hey, wow! It looks like someone else uses IronCAD! I've got IronCAD 10; I could just send you models.
                  Best Regards,
                  Rory Buszka
                  Taterworks Audio
                  • #24
                    Finger joints and dovetails are actually really difficult to do on a flatbed CNC. The problem is that the cutter leaves a round corner in the joint so it doesn't fit tight. The workaround to that in a box joint is to use dog-bone corners, but that presents a problem for speakers in that there are now two little gaps in each joint. Not so good for speakers.
                    You can also set up a jig to hold the piece on end so the cutter leaves square corners, but its not something I anticipate setting up anytime soon.
                    Those finger joints were cut on a laser machine which doesn't have those problems.
                    • #25
                      NaO Note Baffles
                      Thought I'd share the latest product.
                      From this:
                      To this:
                      To This:
                      Time lapse video
                      To this:
                      Needs a little sanding to clean up the fuzzies.
                      Up next is a Cerberus sub. Pictures to come!
                      • #26
                        Quality work, indeed!
                        Audiophiles listen to the equipment, not the music.
                        • #27
                          why do you pocket cut your through cuts for the drivers. That creates a lot more dust and time
                          What g-code software are you using? I run sheetcam on mine
                          You running mach3?
                          Whats your max IMP for cut and job? Just curious as i built my own cnc a few yrs back
                          I used to cut a lot of stuff for guys on here, but i cant keep up with the car audio side of my orders even, and the home audio always takes more time
                          Check out my website: www.uberstealthaudio.com.
                          Now offering cnc cut baffles and other speaker cabinet parts
                          • #28
                            Thanks. They were a challenge!
                            You running mach3?
                            That will be the last time I pocket something that large. I usually do pocketing for smaller cutouts since then I don't have to worry about holding the leftover part in place. Your right though, the large cutouts just take forever and create a lot of dust.
                            I use CAMBAM to generate my g-code. I also use Mach3, seems to be very popular for the PC/machine control crowd.
                            My IPM depends on what I'm cutting. For Ply and MDF I rough and profile at 120IPM with a depth of cut from 3/16" to 1/4". My finish passes are usually .050" and 60IPM. It keeps any deflection under control and gives a nice smooth finish. I could rapid close to 200 IPM, but it really doesn't get me anything with this sort of cutting.
                            Good luck with the CNC, I've been having fun with mine. It's a hobby that has turned into more projects and hobbies!
                            • #29
                              ive been running mine for abotu 3 yrs now. Its a lot of work to keep her running. I swithced over to rack and pinion drives for the x axis.
                              I also run a 3.5hp PC router, but may go to a smaller router after i burn this one up
                              Whats your cutting area? i have abiut 30" x 56"
                              Also, in the center cutouts, no need to hold them in place, they may move a little after they are free, but only every rear once in a while will one bounce out of the hole
                              • #30
                                Thanks for the tip on the cutouts, it will save some time.
                                I use a Hitachi M12VC in mine. I like it a lot. It's quiet, has a 6 year warranty, and it's cheap!
                                Cutting area on the machine is ~50"x100". I built it to handle a 49"x97" piece of MDF.
                                I have a R&P on my x as well, I haven;t touched it since it started running. I use screw drives on the Y and Z. The Z doesn't give me any problems. The y axis though I'm constantly fighting dust on the screws and have had the motor couplers come loose on me a couple of times. Switching to R&P on the Y is a high priority,
