So - why DON'T people go with open baffle?
  • #31
    Re: So - why DON'T people go with open baffle?
    Originally posted by fastbike1 View Post
    Here's what I could use from you guys, being that I think I represent the "People who don't go with open baffle".
    I need something closer to a step list than a "you just need the right drivers, active eq, design is easy" statement.
    I/we know what active EQ means, what we need is how to do it. I know how to wire a passive XO. I have a rough idea how to design one. I can build a cab.
    Give me a design and specify what/how to implement the XO. If we can't do that, if every OB is essentially "I have to specifically design for my room, etc, etc", then you answered the question why people don't go OB. We haven't even touched on size and SAF.
    I understand and can build a design from Paul or Wolf, or Lou, or Chris, etc, but I don't find OB designs here. Lot's of talk in this thread, but nothing more concrete than Orion. If Orion is the solution, just say so.
    Just use Bagby's software and it's seriously as easy as monopole design. I'm serious. The ONLY difference is that when you are preparing your files in the Diffraction Simulator spreadsheet you need to specify that you are simulating a dipole design, not monopole. If you want to you can add in the effects of the walls and floor if you like, I choose to incorporate the floor bounce in all my designs (mono or dipole) but no other boundaries. Aside from that there's no special dipole room considerations, there's no room gain. So with the exception of toggling to "diople" instead of "monopole" in the Diffraction Simulator, there's NO DIFFERNCE to monopole or dipole design. Once you toggle to "dipole" you will see that the rolloff below the step frequency doesn't stop at 6db and the diffraction is about 2x worse, but all this is easily handled in the xo design.
    Once you have your Diffraction files saved, import them into Response Modeller and proceed exactly the same as you would if you were doing a monopole design. Namely, sum the diffraction .frd with the driver .frd.
    Once you have the .frd and .zma files finished in Response Modeller you enter them into PCD and design the xo in exactly the same fashion you would for a monopole design.
    All that is the long way of saying that the only difference is modeling is that you need to toggle to "dipole" instead of "monopole" while creating your .frd files. That's really all there is to it.
    To save a lot of frustration and trial and error it's best to understand which drivers are likely to work well BEFORE you go to all that trouble. Starting with the bass driver, you need to choose a driver and baffle width that complement each other to achieve smooth response down to your desired LF cutoff, no matter how low you want it to go. This is extremely easy to do and doesn't require a computer, you can do it in your head. You take the driver's IB response and sum it to the rolloff of a finite sized baffle. There's a page on my website that tells you how to do this, it's very easy. It's called "simple ob design" and it's in the theory section of my website. I've already linked to it at least twice this week so I won't link it again, google doesn't seem to like it when I constantly link to my own site.
    Once you have chosen a suitable bass driver and baffle width then you can choose a mid and a xo point between them. The first big dipole diffraction hump is an excellent place to xo, and this is the same practice that we regularly use in our monopole design process as well, so nothing new with that concept. The mid driver does not have to have any special qualities whatsoever, it doesn't need more displacement than it would need if the design was monopole. In other words, just about any mid will work just fine as long as you use it above the first big diffraction peak. The difference is that the diffraction bump will be 2x bigger than if it were a monopole design but that's no problem to correct in the xo, assuming you are crossing over right at the diffraction peak, as you normally would anyway.
    The last consideration is the tweeter. You can choose to go full dipole all the way up or you can use a regular tweeter. That's simply a matter of preference.
    As an example, check the measurement I posted. The driver and baffle width have been specifically chosen to complement each other to provide response down to fs with no contouring filters of any kind. If that driver was used as a woofer only in a better design, it ideally would be crossed over to a mid at 700 hz and the xo would take care of leveling the diffraction bump in the woofer and mid response, same as you would do if you were doing a monopole design.
    I really hope this all helps, I realize I've repeated myself several times now but I'm just trying to be as clear as possible.
    Of course if you use active eq you can just disregard this completely and just force the drivers to do what you want.
    Don't even try
    to sort out the lies
    it's worse to try to understand.
    • #32
      Actually MJK's OB paper describes this process much better than I ever could, and while it describes a 2 way with a fullrange driver and a helper woofer the concepts are the same if you go 3 way ( or more). And Dan doesn't like the power response of the wide baffle in that article but the concepts can also be used to choose appropriate driver and baffle widths of whatever size you like.
      Don't even try
      • #33
        I think that sums up the difference in the two design approaches. Most people experimenting with the "narrow baffle" approach are doing it to keep the driver below the dipole peak as far as possible, because that's where the off-axis response is the smoothest. Of course, the downside to this is that you're always operating in the 6dB rolloff region, which means you need EQ and available excursion.
        The other approach is to use the drivers above the dipole peak, where of course, life is easier for the driver. According to the simulations, the off-axis response gets worse. I've never built this kind of design, and I haven't seen any off-axis measurements of one either, so I can't say if the simulations are right or not. And of course, simulations can only tell you so much, the real question is, how does it sound.
        • #34
          This is an EXCELLENT point and very true. I fully admit that it's almost impossible to use passive crossovers if you are trying to keep the response of all the drivers below the first dipole peak. It's a worthy goal but in practice it isn't exactly easy, and at some point it becomes impossible anyway, since higher in frequency you can't get a driver small enough to keep it below the dipole peak, even the smallest tweeter with no baffle will venture into the diffraction region.
          Again this all comes down to compromise and preference. These are 2 entirely different design philosophies, one can be done fully passive and the other can't (or it would be EXTREMELY complex and costly.)
          Don't even try
          • #35
            Originally posted by Paul Carmody View Post
            I'd agree with several points here. First, open-baffle speakers do tend to be large--ergo, low SAF. There are a few exceptions, but for the most part 12"-48" baffles just don't go with most living room decors nowadays...
            +1 on that. In a home with kids, shedding pets, and a reluctance to dust carefully, I could see gobs of dust bunnies growing on the back of open drivers and exposed wires. For you bachelors or those with out pets & kids maybe.
            Lou's Speaker Site [speakers.lonesaguaro.com]
            "Different" is objective, "better" is subjective. Taste is not a provable fact.
            Where are you John Galt? I may not be worthy, but I'm ready.
            • #36
              Grill covers - not just for monopoles.
              I like to see my drivers though.
              Don't even try
              • #37
                LOL, I was just going to post that. It's easy enough to wrap some pantyhose over a dipole speaker
                • #38
                  It is *so* "not so simple" . . .
                  What's a "suitable driver"? Some 15" paper cone breakup engine with a Q of over 1? The point of dipole is clean bass, not paper-flap and boom. How about the RSS315HF . . . excellent on paper and in a box, but a pair of them stacked and you're getting pretty high (30") and wide. Where you going to put the MW/M/T panel? In the stratosphere? What's a "suitable baffle width"? How high do you want to take that woofer . . . high enough to encounter "H" frame resonances?
                  And then there's the ego-driven tomfoolery of "can't do this" or "can't do that" or "can't use a W22" because Linkwitz already did that, and you don't want to design JaO (Just another ORION). Lots of bad design decisions spring from "just gotta be different" . . .
                  "It suggests that there is something that is happening in the real system that is not quite captured in the models."
                  • #39
                    download ABC Dipole and read the design guide.
                    John k.... Music and Design NaO dsp Dipole Loudspeakers.
                    • #40
                      I can second that. John's writeup was a huge help in understanding dipole design (to whatever little extent I understand it).
                      • #41
                        Thanks, I'll give it a read.
                        http://www.musicanddesign.com/A_B_C_Dipole.html
                        • #42
                          Yes, if you want a simple passive xo the woofer driver needs a q in excess of 1 (OR an extremely large baffle), but it doesn't have to be 15 inches. If you think high q woofers sound boomy on a properly designed OB then you've clearly never heard one, or maybe you are confusing a room mode with high q boom.
                          My original suggestion of using 4 GM/Delco 6x9 woofers per side in a WWWMTW places the MT right at ear level, where's the problem? Driver height and placement is not really an issue if you plan ahead, like you would for any mono design. (And again, I'm not saying that design will win awards but it's a way to make a super simple passively crossed extremely narrow flat OB for free. And there's no need to use them or any other woofer up into the breakup region.)
                          I have no idea what you are talking about here.
                          What I have described is SO SO simple. Apparently you have different design preferences that are extremely complicated. I'm not telling you that your goals and designs are wrong so why are you telling me the methods I described are? There are several ways to design an OB, some are extremely complex, some are simple. I don't prefer either method. They are just different. I was just trying to point out that it CAN be as simple as you want it to be.
                          The Orion is not the only way to do things.
                          Don't even try
                          • #43
                            Insufficient bass. And probably not very good sound overall, either.
                            Build it, you'll see . . .
                            There are a number of examples of "dipole done right", ORION, of course, topping the list. The "oh so simple" dipole designs either fall far short on performance, or remain imaginary. When "the methods you described" produce a speaker that sounds as good as ORION in a reasonable sized package then I'll have to reconsider my assessment of the methods. Until then . . .
                            • #44
                              Not insufficient at all, since it only goes down to 60 hz it'll go pretty loud, especially if high passed appropriately. Have you modeled the suggested configuration? I doubt it. For the extra bottom octave that Orion does it would need lots more displacement but I'm happy with a sub on the bottom. The drivers are fairly high quality for what they are and they don't sound bad. And they are free...
                              I have no way to know what Orion sounds like and you have no way to know what anything I build sounds like so I don't think anyone will be changing their mind. Regardless, I'll share my OB designs when I get around to them but it won't be anytime soon and I suspect you will dismiss anything that isn't an Orion anyway. Until then...
                              I'm done with this, we're just going around in circles. I've made my point several times already.
                              Don't even try
                              • #45
                                Assuming we're talking about full dipole loudspeakers here (20Hz-20KHz)
                                The main detractors are size and/or complexity. Since you need ~4 times the displacement to reach the same low frequency SPL as a monopole woofer.
                                SIZE:
                                A passive dipole therefore needs to be large. Some people use wide baffles >20" wide. Throw SAF out the window- just live with your speakers in the basement. A good case example for something narrower is thes- Jamo R907- uses dual 12" woofers per size, and reaches down to around 35Hz and still 17" wide.
                                COMPLEXITY:
                                If you want to reduce the size then you'll need to go active/EQed. A good case study is the Orion- 14" wide. But with only dual 10" woofers you're excursion limited below 40Hz, so if you want to reach the bottom octave you need single 12" subwoofers (see Thor)
                                Meanwhile, 35-40Hz is an walk in the park for your traditional vented/passive radiatored floorstander speaker, utilising only a single 8"-10 woofer in a compact 9-11" wide cabinet.
