Re: So - why DON'T people go with open baffle?
Mine ar four feet from the front and five feet from the back of built-in wall-to-wall bookcase (with a top shelf at five feet high) . . . I guess you'd call that five feet from the wall, with diffusers
. Sometimes I move them out a foot further, sometimes (social occasions) a foot back (that's the limit of motion . . . the cables feed through the floor to amps in the basement, and there's not much slack). It doesn't make a lot of difference, but further out from the wall seems "better".
It's a problem, and one of those "compromise" things. We'd all love a (good, cheap) planar with sufficient output to below 1500 Hz. that didn't beam in the vertical axis (or the horizontal). Let me know if you find one. Going to a "two-way tweeter" has some advantages and some disadvantages . . . you can get a better horizontal polar at the cost of the vertical polar . . . we can argue endlessly about which gives the better overall response in the listening area. You could probably substitute RS28 tweeters for the Millenniums and save a bunch of money with little to no loss of performance, but the RS28 is even deeper, which would make the mounting even more problamatic. Scan has shallower tweeters that would certainly work, but they're just as expensive. You can *never* optimize for just one thing and come out with a good speaker.
It's the same "compromise" question again. The XLS drivers are fine at least an octave higher than they're used in ORION, what limits them in ORION is cavity resonance in the H frame. And it is as deep as it is so the speaker can be as narrow as it is (to match the midrange baffle and present a smaller footprint in the room). They could easily go higher if the baffle was wider . . . but . . .
It depends on what you're optimizing for, and what compromises are acceptable. Full range dipoles are quite cost-effective *for what they do best* . . . accurate reproduction of acoustic music in a "medium" sized listening room. I'd put them far from "first choice" for a dedicated HT installation, with it's very different acoustics and SPL requirements. They're not "party speakers" either . . . "dipole" and "disco ball" may both start with "d", but they don't belong in the same room. Different musical tastes and different listening environments point to different speakers . . . the wrong speaker is never "cost effective", the right one, in the right place, may be "cost effective" regardless the price.
Originally posted by spasticteapot
View Post
View Post
View Post
View Post
