Nubie's Build - The Copper Project
  • #31
    Re: Nubie's Build - The Copper Project
    Originally posted by critofur View Post
    you don't need binding posts just to play them before they're finished. Drill a small pair of holes with no space between them just large enough to push through speaker wire - temp. solution to getting the signal into the box without running the wire through the vent...
    Found out that my son's hand is small enough to go through the front port hole. When it comes time to veneer I'll get him to undo the posts from the inside.
    Finished soldering the crossovers and all the wiring.
    May fire them up for a test run tomorrow!!
    Light is at the end of the tunnel!
    Ted
    • #32
      :D:D:D:D:D:D:D:D:D:D:p
      Whatever, Cheesehead.....;)
      Junior
      • #33
        I ordered some of those binding post plates, they're really nice!
        रेतुर्न तो थे स्रोत
        return to the source
        leviathan system thread
        deadhorse thread
        shockwave build thread
        instagram :: greywarden_13
        • #34
          HELP!!
          Hooked these up for a test listen and nothing is coming out of the tweeters in either speaker.
          here's my x-over wired up
          here's the x-over schematic.
          anyone see anything wrong?
          thanks
          Ted
          • #35
            Only thing I can tell from the picture is some cold solder joints. But if that is not the case then check continuity before the tweeter. It could be the series resistor is bad also.
            Thanks ,
            JB
            • #36
              Ouch, that's a bummer. Check every connection for solid wires (nothing loose), if so, then if you have mounted the drivers already, pop one tweeter out and play with every connection until the tweeter makes sound.
              One tip that some people miss, if you are going to solder capacitors with short leads like that, the heat can damage the cap. You can use a pair of hemostats or small locking pliers between the solder joint and the cap body to prevent damage.
              If you have a cheap speaker lying around (like from a $5.99 desktop computer speaker deal), you can connect that to the crossover tweeter outputs and try bypassing the crossover components one by one until you find the problem (playing some sound at a low level).
              Tangband W6-sub
              • #37
                DJD, Don,
                thanks for the tips and insight.
                Like you said, it's probably a loose connection or a cold solder joint. Hopefully its not a bad cap. Love the idea about testing by bypassing components.
                Will dive into it this evening.
                Ted
                • #38
                  OK, took apart whole crossover and re-soldered everything with a solder that had more silver (audio grade vs RatShack grade, dunno why I did that, ugh!) and everything works now!! (cold solder? like DJD said?)
                  Anyhow, still need to seal the baffle, but preliminary listening tests are pretty darn good!
                  I'm a happy camper!!!
                  Finally figured out the cheese banter... WI!!
                  I went to school in Chicago way back when.. and went to WI for the Lands End Outlet!!!
                  Ted
                  • #39
                    wait till after the superbowl:eek:
                    what school?
                    what will you do for feet?
                    in the future, use a jumper to bypass each component to find the bad joint.
                    • #40
                      Odd that you had two bad solder joints and both on the tweeters. Are you sure you didn't change the crossover schematic after you rebuilt it? In looking at your picture I can't quite figure out how you have the inductor wired (I'm assuming you have it right, but you know what they say!!!)
                      Glad you like 'em.
                      M.
                      PS, don't neglect to send pics of your finishing process too!
                      • #41
                        So glad you go them working. You might want to practice your soldering skills sometime before your next build. It's not hard, but involves good timing control - sort of like making an omelet.
                        Here's a nice guide. http://www.kingbass.com/soldering101.html
                        Tangband W6-sub
                        • #42
                          Update:
                          Been real busy at work, but got a chance to work on the Coppers, but also did some other things inbetween.
                          Added some corner braces to hold the front baffles
                          1 coat of Zinser primer and three coats of automotive primer on the baffles with sanding inbetween.
                          Also found time to build a Pass DIY B1 Passive Preamp for my Dynaco ST-70
                          Finally got a chance to buy a table saw. A bit too late for this project though, a Dewalt 745.
                          Bought some copper paint, but wife nixed the copper color idea, so semi-gloss black it is.
                          And my veneer from Tap-Ease finally arrived.
                          So currently using the cold-press method to attach my veneer.
                          More photos to come.
                          Ted
                          • #43
                            Hey, I like that corner clamping method. I'm gonna have to steal that. :D
                            Twitter: @undefinition1
                            • #44
                              Ted,
                              Make sure you have those enclosure seams sanded and filled perfectly flat or you'll see the flaws through the veneer, and by then it's too late! BTW, it's called Copper Project for a reason...not Semi Gloss Black project....darn wives. :p You would have loved the copper...
                              What veneer did you choose? The Tape-Ease office is about 40 minutes from my front door so it always freaks them out when somebody walks in off the street wanting to buy a sheet.
                              Great corner gluing block! Good idea that many here will adopt.
                              Marty
                              • #45
                                Originally posted by martyh View Post
                                Ted,
                                Marty
                                Agreed, go over those seems with 80 grit and 120 after that and make sure you cant feel any transition between the 2 seems. If you dont get them flat and smooth you'll either see the imperfection as Marty said, or worse...you could end up with veneer splits/lifting/bubbles.
                                Good luck bud !
                                PS- I second the copper paint motion. Black?...come on wife !!!! :D
