Originally posted by rogoll
View Post
Buyout Transducers
Re: Buyout Transducers
Turns out that the last order of Polyswitches I got from Erse were the exact same part (WH 60 65).
By the way, if you would rather use fuses to protect your drivers. I believe the formula is A = SQRT(P*Z), where A = ampacity of fuse, P = wattage of driver, and Z = driver impedence. This is as best as I can recall from an old speaker building book.
Originally posted by rogoll View PostAint Google wonderful? Here's a datasheet listing the specs on the WH 60 065 "polyswitch" (although these are some other brand, I believe). As best as I can tell (electronics school was many, many years ago...), these are rated to provide protection for 10 watt devices, which would correspond with the rating listed on PE's product page. Mystery solved.:D
Sorry guys I stand corrected. I just pulled them out of the closet to check. You are absolutely right.
I'm pretty sure that it's a polyswitch. I have several polyswitches of various values and the construction is identical. These are a little too "glossy" to be ceramic caps. Also, the leads can be seen extending onto the sides under the glossy exterior, as on other polyswitches.
I should have posted a link to the single driver version, as someone else did. You can't see this component on the pictures of the dual version shown on the PE product page (it's on the back side of the units pictured).
Originally posted by rogoll View PostDoes anyone know what the small brownish-orange disk on the buyout transducers are. Anyone know for sure? BTW, is the electrolytic cap on the paired set a 0.5 uF?
Thanks,
Leonard
When you get a pair you get a HP and a LP . One has an e-cap and the other gets the ceramic.
That's actually a ceramic cap. We are talking a budget item here. Those drivers are fun to play with.
Strange, that's not shown as being on there in the first picture:
the thing by the red wire? looks like a cap for a highpass filter to me.
If you are asking about the thing which appears to have pleats in it ... a coil spider.
I don't see it - are you talking about the spider?
They are basically like a speaker without a cone. Same basic coil in magnetic gap design. You just glue the device to a radiating surface.
