Ultra-budget MT floorstander for about $100 a pair
  • Ultra-budget MT floorstander for about $100 a pair
    see updated crossover about 10 posts down
    For this project, the name for which has yet to be finalized (there are a couple candidates), the goal was to put together a speaker that would sound good, (especially compared to cheap floorstanders in big box retail stores), be easy to build even for those with limited woodworking skills and minimal tools, and with a price in the $100 range for parts & materials, not including finishing. I also wanted to put together a fairly well-documented build, since this was targeted at folks new to speaker building. For those of you looking for something smaller, i have a PC speaker / HT satellite in the works for about $25 per speaker.... stay tuned.
    Some of these goals were satisfied better than others -- the documentation and cabinet drawings are still in progress, and the price bumped up a little over the ambitious target, but you're probably still less than $110 a pair including MDF, and probably a few more bucks (vinyl laminate and painted baffle) to be completely done.
    Even though the drivers are buyouts, they're expected to be in stock for a while. The 12-ohm nominal woofer (which measures more like a nominal 8-10 ohm) makes this design safe for any amp. I used the Bravox 06BV02S in the prototype because i have about a dozen of them, but the 06VB03B is very similar, but sacrifices a few hz of F3 but uses a smaller box. For those that prefer the gray-cone bravox drivers' appearance, i haven't tested them, but they're probably a drop in replacement. (i'll test it for free if anyone sends one postage paid).
    The tweeter is the Peerless India T25QX01, which has a custom faceplate meant to match up with the Bravox woofers. this means that both drivers are surface mounted, but have rounded frames to reduce diffraction, and a jigsaw is more than sufficient to cut the holes because you won't see any rough edges on either one. the port is a "press-fit" design with a slight lip that will also cover some slightly less than round holes.
    The cabinet is about 1.45 ft^3, tuned to about 45 Hz. (8.5"w x 36"h x 12.5"d. if you use the bravox -03 woofer that's currently in stock, you can shave this to 10.25" deep.) Both model with F3's in the upper 30s, though the -02 woofer that's no longer available shows about 1dB higher below 100 Hz. The lower bass isn't overpowering, but gives a good full-range sound. Since the tweeter is crossed fairly close to its Fs, they're not going to play extremely loud without some increasing distortion, but i haven't noticed any issues at normal levels.
    The in-room measured frequency response is pretty good, with a slight dip around 4,000 hz, and otherwise +/- 2dB. the distortion measurements at 90dB reference level were pretty good too. all of the measurements were done with ARTA at 96kHz, using a pioneer home theater receiver run in stereo mode for the amp, and ART tube MP pre-amp, and a dayton EMM-6 microphone.
    Current pricing list for version 1 crossover:
    (2) $10.25 - Bravox 06BV03B 12-ohm blue poly woofer
    (2) $9.60 - Peerless India T25QX01 1" tweeter
    Bravox 06BV02B
    (2) $6.25 - .90 mH 20ga inductor ($7.25 for 18ga)
    (2) $3.49 - .15 mH 20ga inductor
    (2) $1.25 - 3 ohm dayton 10W resistor
    (4) $1.00 - 4 ohm dayton 10W resistor
    (2) $1.25 - 7 ohm dayton 10W resistor
    (2) $1.25 - 12.5 ohm dayton 10W resistor
    (4) $0.61 - 10ufF nonpolarized electrolytic cap
    (2) $1.34 - 1.0 ufF nonpolarized poly cap
    (4) $0.61 - 12ufF nonpolarized electrolytic cap
    (2) $0.56 - 6.8ufF nonpolarized electrolytic cap
    (2) $3.49 - binding post terminal cup
    (2) $3.15 - 2.5" flared port tube
    version 2 crossover is below, direct link here
    all told, including port, posts, etc, these will run about $90 / pair in parts (maybe $94 if you add screws and some insulated terminals. if you buy everything for 2 sets and get the quantity discount for 4+, you can hit the $80/pair in parts threshold).
    any feedback or constructive criticism appreciated.
    Re: Ultra-budget MT floorstander for about $100 a pair
    pretty cool
      Very nice. Do you have the xo drawing? Can you compare these to the tritrix?
        yup, had to switch computers to post it (also noticed i had the old cap values in the post, so i corrected those now).
        unfortunately, i don't have a tritrix, so i can't make a great comparison. i'd imagine from what i've seen the tritrix gets a decent amount louder, and they appear to have a little flatter frequency response than these. since the surface area on the tritrix's two drivers is a little larger, that and the TL may give it a little better extension. and mine doesn't come with a fancy knock-down cnc'd cabinet kit
        also, here are larger versions of the distortion charts... PNG look better, but the size was really limited. graph is the same, just scales up better in this one.
          Patrick, you are a man after my own heart
          Those little aluminum tweeters are very nice. I bought a bunch of the faceplate-less ones last year, still have three of them.
            I only have one complaint.
            The 2 C1 values (1uF/6.8uF) in the woofer portion allow the transmission of ultrasonics to be shorted to ground, possibly causing amplifier instability. I would recommend a 4 ohm resistor in series with the 1uF value, or a 2 ohm minimum in series with the 6.8uF value to avoid that potential issue.
            It's otherwise very well thought out and looks like a good build for a first-timer to attempt.
            Thanks for sharing!
              complaint appreciated, and changes made. the 1.0 uF was a late add during measurements, and i'd run an impedance sweep but hadn't thought about stuff outside the audio range.
                ha, thanks. they're actually pretty good. i'm also glad my blue woofers didn't have the cone sag problem some of the other batches did. anyhow, speaking of our projects to give something back to the community through some super-cheap entry-level designs, watch out for this little guy, he's up next....
                  Another excellent tweeter choice!
                  I have a three way coming up using two these, one of these, and one of these. Medium sized floorstander with full baffle step. Won't go particularly low, but will be capable of some decent output.
                    version 2. after listening to them for a week and thinking they sounded a little forward compared to my primary set of speakers, i decided to take a hack at a more relaxed presentation, and one that actually gets a tad more sensitivity (to me, this suggests i should keep optimizing the original design). i went with a simplified crossover that cuts the part count, and i think overall i like this one better. it measures slightly better in-room too, but not everyone that builds one will have the same room dimensions i do.
                    the parallel resistor can be adjusted from 2.4 up through 6 ohms if you need to make the tweeter a little brighter or softer.
                      oooooh...
                      I've always wanted to try a speaker with waveguide tweeters.
                      From what I gather, it's a good thing, allowing the tweeter to be crossed lower, among other benefits... why isn't it done more often?
                      Form does not follow function
                      Form is simultaneous to function
                        Originally posted by lunchmoney View Post
                        oooooh...
                        I think the reasons are two-fold: one is that there is an association with WG and honky sound, and two: cost plus complexity.
                        Both reasons are no longer valid, not really. This day and age of cheap measurement tools and wide spread availability of woodworking tools has made addressing the difficulties much easier.
                        I have used the larger brother of the WG tweeter in the micro monitor above, and I really liked how it sounded.
                          pair #1 is now basically finished up. going through the listening test, but sounding pretty good so far. these are just krylon'd MDF baffles and the PE cherry vinyl. (the color actually looks deeper in person). overall i'm pretty happy with this project. I think the crossover should also work in a bookshelf version, maybe 11-12" tall, tuned to about 50 hz. may build a matching pair just to test.
                            Nice work - I'm sure they'll live long and prosper.
                            (snicker)
                            But really, great work!
                            Marty
                              Those are pretty sharp looking! For reference, here is the FR plot of the Bravox 6.5" silver cones taken on about a 9" x 12" baffle with no roundovers:
                              Probably quite close to a drop in, although the woofer frame is different, cosmetically. Not enough to make much of an impact I imagine.
