cheap sub
  • cheap sub
    help needed to build a cheap sub. any advice helpful. i am new at diy
    Re: cheap sub
    What are your cabinet size and budget constraints?
      Re: cheap sub
      $150 buys a 12" DVC Dayton driver and the SA100 plate amp.
      Good in 3cf with a 4"id vent.
      chris
        Mods: Please move this to TechTalk forum..
          Re: cheap sub
          What do you plan to do with the cheap sub? And how cheap? Do you have all the tools to build it?
          Some more info will get more informative replies,
          Duane
            Re: cheap sub
            Duane
            budget is about 150 and will be used for ht
              Re: cheap sub
              and i do have tools
                Re: cheap sub
                chris
                This looks good... Except the sub is out of stock! Should be in soon though. Don't forget to brace the cab.
                Duane
                  Re: cheap sub
                  chris
                  what is id vent? how long and where to place on box
                    Re: cheap sub
                    ID = Inner Diameter. He means to use a round port. You can use PVC or PE has some available for sale.
                      Re: cheap sub
                      4" inside diameter vent by 10" long. I use PVC pipe. 3 cu. ft. box. I like to put the driver and vent on one side, and the amp around the corner. Then, you can have the driver, port, and amp visible, or all hidden (if any kids are coming around).
                      Chris
                        Re: cheap sub
                        Remember to throw some bracing in there.
                        3 cu ft is pretty big, it'll boom and resonate if the walls aren't tied together.
                          Re: cheap sub
                          thanx for info!
                            Re: cheap sub
                            Chris
                            port tube in middle under driver or on bottom corner?
                              Re: cheap sub
                              [QUOTE=Chris Roemer;1721982]4" inside diameter vent by 10" long. I use PVC pipe. 3 cu. ft. box. I like to put the driver and vent on one side, and the amp around the corner. Then, you can have the driver, port, and amp visible, or all hidden (if any kids are coming around).
                              Chris[/QUOTE
                              would this sound better thatn the triska sub using the 8" inch dvc and two pr's
