Has anyone used this woofer? Thoughts? I'm thinking about two of them as a three-way with a Fountek FR88EX.
8" Neodymium Woofer 4 Ohm - anyone used it?
"Based on my library and laboratory research, I have concluded, as have others, that the best measures of speaker quality are frequency response and dispersion pattern. I have not found any credible research showing that most of the differences we hear among loudspeakers cannot be explained by examining these two variables." -Alvin Foster, 22 BAS Speaker 2 (May, 1999)Tags: None
Re: 8" Neodymium Woofer 4 Ohm - anyone used it?
I've never personally used any of them, but others will want to know which driver you are talking about. Is it by chance this one: http://www.parts-express.com/pe/show...number=299-098RYAN N.
"Why do you have the stereo on while you're watching TV?" - "....Cause I like to party."
RSS390HF Build - http://techtalk.parts-express.com/sh...d.php?t=224998
AviaTrix Build - http://techtalk.parts-express.com/sh...d.php?t=230372
Wolf's PC Speakers Build - http://techtalk.parts-express.com/sh...84#post1838384
Overnight Sensations MT Build - http://techtalk.parts-express.com/sh...ation-MT-build
Technically, that's not a three-way. The number of 'ways' is the number of passbands in the crossover. You would still be describing a two-way, unless you're planning to use a tweeter above the FR88EX. If you will be shading the lower woofer in your dual-woofer config to provide baffle step compensation then it's a 2.5-way, because the upper woofer overlaps the lower woofer's passband.
It's time to pick up a copy of the Loudspeaker Design Cookbook and read up on your terminology.Best Regards,
Rory Buszka
Taterworks Audio
