Re: MiniByzy (Mini Byzantium) Build Thread
Given the above, I assume panels that are complex curves would be somewhat more advantageous, though of course even more difficult to produce in wood, especially if the panels are to be veneered.
I don't want to sound facetious in the following, but I have been wondering about the visual/audio neurological connections that make things that look good, sound good as well. I suppose the way we see some shapes reinforces in some way, the way we hear the sound these shapes produce.
This is also interesting to me as a friend and I are working on some prototypes using old Epicure drivers. He wanted the inverse dome tweeters set back into the baffle so the two drivers would be as close as possible to the same plane. The hitch was that he also wants the drivers on the baffle plane, which was to be slanted. The cabinets are truncated pyramids in which 3 sides are slanted, the back face is square to the base. Both requirements are not possible so I cut a bowl shape in the baffle to produce a compromise we hope will produce the desired effect.
What interests me about your approach is that the waveguide is curved like a trumpet bell(?), rather than a bowl shape. I assume there is an acoustic advantage to the one over the other? I have photos of the baffle for the prototypes that show the inverse shape I cut with the Epicure tweeter in place. I'd be interested in your comments about this approach, however, I need to figure out how to reduce the file size so I can attach the photo file.
Thank you again for your response. tna
Non rectangular baffles will have different diffraction signatures, and can be beneficial. There's also the inherent advantage of curved panels to adding stiffness and strength compared to their flat counterparts. It's much more difficult to set a curved panel into resonance than a flat one.
The interior being a chamber composed of non-parallel sides, the chances for standing waves to form are reduced, but when properly damped with acoustic stuffing, standing waves shouldn't be a problem in rectangular enclosures either.
This shape was chosen purely for aesthetic reasons, based on the floor standing 3-way in my avatar. Ed did with this, what he wanted to do to the big ones, by adding the curved top/back.
The main reason for the waveguide, other than the really cool look it imparts, is simply to allow us to easily cross the tweeter at 1KHz to an 8" woofer. Preliminary models show that the filter will be down 20dB at 1KHz relative to the upper frequencies in LR4, which should allow it to keep up with the woofer and provide and even cleaner upper mid presentation.
