Re: MiniByzy (Mini Byzantium) Build Thread
This certainly is an interesting and unusual project, I can see the many challenging construction problems, as well as see there is no shortage of ability solving these. I also understand the aesthetic appeal these cabinets represent.
In that I am only just beginning to work with semi-non rectangular enclosures for speakers, I am curious about the acoustic advantages this cabinet design provides over flat sided enclosures.
I've read through several of the posts looking for comments and explanations that discuss the advantages, and may have missed these, but wonder if someone could point these out or provide a brief explanation of the advantages, or perhaps suggest a source for an explanation of the advantages of this sort of enclosure.
I look forward to seeing photos of the finished project.
tna
Originally posted by DoubleTap View PostYou could only paint the top if we did it after veneering. Too much flush trimming, sanding, finishing, sanding, finishing, buffing, etc as part of veneering to keep from screwing up the paint if done before veneering.
Wow . . . that's really nice.
What about extending the black metallic to the top/back, with only the sides veneered?
Originally posted by DoubleTap View PostIf you could draw up the shape of the cabinet bottom in CAD, I could get some stand top/bottom plates cut and use the same basic stand I do for the Cirrus. That shape with the 5* tilt would compliment it well.
Originally posted by DoubleTap View PostGloss metallic black for the front baffle, maybe Pelin Burl for the cabinet?
Only a discussion so far. We sure would like to have something that compliments the lines, and I do have a couple ideas. I'm sure Ed and Ryan do too.
Looks like the feet will consist of a set of 4 hardwood discs that have been turned on a lathe for a bit of shaping and accents, so any stand of sufficient platform size will work. But once we fix those positions, I'd like to see a platform custom fit to the bottom, to give the port a wide open exit space.
As for the vertical portion of the stand, it would be nice to see the use of the same curved panels to fashion the structure.
Originally posted by greywarden View PostAre there any plans for matching stands?
The final surface prep. You can see the tell-coat on the lower right as the process of smoothing the epoxy finish begins.
Originally posted by PWR RYD View PostYes, Bondo would explain the pink areas, but what is the glossy coating applied over the entire front? Bondo dry's flat not glossy.
Originally posted by PWR RYD View PostWhat is the light brown (almost pink in some spots) product that has been applied to the front of the baffle? And is it hard so that it doesn't load up sand paper?
His comment to me was that it set up very quickly, and was a breeze to sand.
Originally posted by D, Rose View PostThen I'll build a set without and we can all hear if there is a difference in Chicago(?) That'll be a fun experiment.;)
At this point Ed, anything more would be like picking dust particles off the Mona Lisa. ;):D
