6.5"-7" Woofer Suggestions For .75ft3 Boxes...
  • 6.5"-7" Woofer Suggestions For .75ft3 Boxes...
    Other than the Dayton RS180, I'm looking for 6.5"-7" woofers that will work well in a .75ft3 box.
    Most I've looked at seem to favor .5ft3 boxes or smaller.
    Thank you...
    Re: 6.5"-7" Woofer Suggestions For .75ft3 Boxes...
    Thank you...
    http://www.parts-express.com/project...oject=Usher701
    http://murphyblaster.com/content.php?f=usher2way.html
      The Peerless 831735 buyout would hit 40 hz in 3/4 cu. ft. with a 2" X 7" port.
      Lou's Speaker Site [speakers.lonesaguaro.com]
      "Different" is objective, "better" is subjective. Taste is not a provable fact.
      Where are you John Galt? I may not be worthy, but I'm ready.
        Here's a good start on a proven design.
        http://techtalk.parts-express.com/sh...d.php?t=223120
        I have enough crossover parts and drivers for 3 pairs of these. Contact the OP for the crossover design. The speakers are currently on a very low buyout sale, which makes them an excellent value. These are the same 6" drivers used in these $2500 speakers:
        http://www.greenmountainaudio.com/rio/
        Modding the Lepai T-Amp
          Thank you...
          You can always add filler to reduce the internal volume. Chunks of wood, or maybe styrofoam.
          I like the bass and midrange of the 831735, but the x-over may give you fits like it has me. A lot will depend on where you want to cross, and how the speaker interacts with the room.
            You didn't state a price point so I will throw these out there as suggestions:
            the Usher 8945A and 8945P
            How high are you trying to cross them over?
            Craig
            I drive way too fast to worry about cholesterol.
              More volume in your enclosure is a great thing to have for the woofer - most of us are trying to figure out how to get our speakers SMALLER.
              But anyway, check out this thread:
              http://techtalk.parts-express.com/sh...hlight=W6-789E
              Folks that have used them mostly seem to be quite pleased with that woofer. It does have a remarkable combination of sensitivity + smooth top end.
              Check out this post: http://techtalk.parts-express.com/sh...9&postcount=57
                No, price isn't really an issue.
                How about the Usher 8948A?
                I will cross no higher than 2KHz to avoid beaming.
                  If price wasn't an issue this is definitely what I would go with:
                  https://www.madisound.com/store/prod...roducts_id=929
                  Craig
                    8948A is perfect in a .75cu/ft, gives an EBS-3 alignment with an F3 in the high 30's.
                    Vapor Audio
                      I got one design working with a 1.8k x-over. (Best I remember) But in trying to build a second design with a sloped baffle and different tweeter, I just can't get things to match up. The tweeter is partly to blame too. I prefer woofers that are a little easier to cross where I want.
                      Edit The working design x-over is 2.5k.
                        Thanks DoubleTap...can you please explain what a EBS-3 alignment is?
                          Extended B a s s Shelf
                          If you take a driver with a Qts less than .4, you can slightly oversize the enclosure, and tune lower, to create a "shelf" of extended low end response. Instead of "flat" to the -3dB point, EBS alignments might sag 1dB, stay flat for a bit, and then finally drop off, but at a lower frequency than the "flat" alignment.
                            Thank you Pete!
                            Now I see what's going on with that type of alignment.
                              If you are trying to keep cabinet width down you could run 2 woofers. Use one for BSC.
