LIMP impedance and T/S parameters shift
  • LIMP impedance and T/S parameters shift
    Hello all,
    I'm using LIMP with the ARTA box.
    I'm getting the impedance peaks in higher frequencies then I should, for example the Hertz 165DSK.
    Also there's a slight noise apparent in the response - why is that? I've checked all my grounds in the jig and the cables as well. Maybe I missed something?
    Thanks
    Adam
    Re: LIMP impedance and T/S parameters shift
    Does the noise appear consistent - regardless of where and how the DUT is placed?
    ( blips can be caused by reflections )
      well it moves a bit on the screen every frame (LIMP's refresh rate).
      I'm moving the driver around within about a meter, vertical horizontal etc. but the pattern stays the same.
      It's also apparent when measuring a resistor.
        How is driver positioned?
          Open air. moving it doesn't change measured FS frequency.
            I thought perhaps there was an "outside influence" creating noise
              As I said, the noise is there with resistors (or capacitors) as well..
              Thanks anyway
                This may be a long shot, but if you're using a laptop, try unplugging the power supply and run solely off the battery.
                  Maybe not...
                  I was surprised ( with my WT2 ) how sensitive it was.
                  I turned off nearby devices.
                    Stays the same between my laptop and desktop..
                      Anyone?
                        Originally posted by adamharzuf View Post
                        Hello all,
                        Thanks
                        Adam
                        If the noise level is fairly constant then look for a way to increase the test signal level. This will to increase the overall signal-to-noise ratio and reduce the noise artifacts on the impedance plot. What is the level of the test signal? Somewhere around 1 Vrms should provide reasonable noise immunity depending on the test setup.
                        Regards,
                        John
                        John L. Murphy
                        Physicist/Audio Engineer
                        True Audio
