Thought I'd post this to narrow down the tweeter / fullrange selection for an open baffle speaker with an htpc acting as the crossover. Since frequency response isn't a huge issue as the crossover is dsp based, distortion becomes my primary concern. The tweeter/ fullrange will be paired with a peerless sls 12" woofer. Distortion needs to be low down to at least 500Hz( planning to set the crossover at around 700Hz, 4th order) and the frequency response range preferably past 16k. The range can be compensated somewhat however. So can anybody name a driver that fits this criteria?
If you were to pick a full range driver based on low distortion what would it be?
Re: If you were to pick a full range driver based on low distortion what would it be?
Originally posted by ElectroBiT View PostThought I'd post this to narrow down the tweeter / fullrange selection for an open baffle speaker with an htpc acting as the crossover. Since frequency response isn't a huge issue as the crossover is dsp based, distortion becomes my primary concern. The tweeter/ fullrange will be paired with a peerless sls 12" woofer. Distortion needs to be low down to at least 500Hz( planning to set the crossover at around 700Hz, 4th order) and the frequency response range preferably past 16k. The range can be compensated somewhat however. So can anybody name a driver that fits this criteria?
http://www.parts-express.com/pe/show...number=295-346
Considering the off-axis response, the dayton point source looks very promising. Do you happen to have THD plots for it? The Fountek looks like a good candidate too but I see no off-axis response in the spec sheet.Know where I can get one?
Thanks,
Matt
Originally posted by ElectroBiT View PostConsidering the off-axis response, the dayton point source looks very promising. Do you happen to have THD plots for it? The Fountek looks like a good candidate too but I see no off-axis response in the spec sheet.Know where I can get one?
Thanks,
Matt
http://www.parts-express.com/pe/show...-344&FTR=ps180R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
Check this thread for lots of details on the PS220
http://techtalk.parts-express.com/sh...d.php?t=221465R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
Thanks,
Matt
1. Focal 3W2 Be
2. Fountek FR88-EX
3. Scanspeak 10F-4424G Discovery
http://www.mobileelectronics.com.au/...range-roundup/
The Jordan Zaph graphs like this:
Dan"guitar polygamy is a satisfying and socially acceptable alternative lifestyle."~Tony Woolley
http://dtmblabber.blogspot.com/
http://soundcloud.com/dantheman-10
How about this venerable JBL Control 1. Its 5-inch woofer is almost a full range driver.
The spec has distortion graphs run at 10 watts. I wonder how does it compare to the modern drivers?
http://www.avstumpfl.com/common/data...front&offset=1
Originally posted by dantheman View PostThe Jordan Zaph graphs like this:
Dan
XJ-92 is an excellent little driver. Stick it in to a folded pipe or an MLTL and you'll get surprising bottom end out of it.
But yes, full range is full range and as anything else they have drawbacks. Personally, I'd take a XJ92 based system over Behringer monitors any day.
Now you've gone and done it. :D
Originally posted by r-carpenter View PostXJ-92 is an excellent little driver. Stick it in to a folded pipe or an MLTL and you'll get surprising bottom end out of it.
But yes, full range is full range and as anything else they have drawbacks. Personally, I'd take a XJ92 based system over Behringer monitors any day.I was so much older then, I'm younger than that now.
Originally posted by fastbike1 View PostNow you've gone and done it. :D
but in all seriousness, put a 92 based TL up against mentioned monitor, throw some Jazz on and be amazed. 92 will image like you wouldn't believe, things sound pleasant and natural. Behringer, well, it'll sound good and may have advantages on some music but not to me and not with my choice of music.
