I've been working on a 2-way TL based on the RS150S-8 and Peerless BC25SC06-04 for the last few weeks. Today I got them cobbled together with clamps to hold the front baffle in place. First impressions are they are detailed, with spot on imaging and no discernible on-off axis harshness. Overall, a speaker that will see the effort to finish in nice veneers and long listening sessions.
The core design is based on work done by patrickm. My sincerest Thanks and Gratitude for his generous approval to use his designs and for tailoring his original designs to match my drivers and understanding of TL parameters.
When finished the x-overs will be mounted in the base and easily accessible for repair or modification. There is an enclosure for the tweeter which also aids in maintaining the TL taper and proper woofer placement.
Finish: Cabinet and base will be figured walnut, with tiger stripe maple baffle. The port will have a solid tiger stripe maple flare, and the baffle will have 3/4" round-over on vertical edges and top. The base will have an 18 deg taper in all directions away from the cabinet. Final finish....leaning toward tung oil or wipe-on poly.
Single terminal posts will be installed in the rear top surface of the base, easily accessible and out of the way when cleaning.
