sony buyout
  • Re: sony buyout
    Originally posted by jmw View Post
    hmmm im liking the vifa's more then the horns
    im not good at crossover ! i need some one to assist me in 12 line with one of these ! 4 ohm or 8 final load
    http://www.parts-express.com/pe/psho...79-168&scqty=1
    12 will give you a 6 ohm system impedance, not 4 or 8.
    You would make 4 groups. Each group consists of 3 drivers in series for 24 ohms. You would put the 4 groups in parallel for 6 ohms.
    “I cried because I had no shoes until I met a man who had no feet”
    • Re: sony buyout
      What program do you use for those mountain charts?
      Originally posted by [email protected] View Post
      the omni noise is not 100% steady but i think the voltage was around .15. the spl was steady around 85db. perhaps a bit abusive for this driver. i did not include vas as i have not figured that out yet. i will learn that when im forced to. second fr is 15degrees off axis.
      An apostrophe with an "s" does not mean plural.
      Speaker's IS NOT PLURAL.
      • Re: sony buyout
        so if i wire all 12 to 6 ohms add a 4 ohm vifa tweeter and just cap it off at around 3khz and do a band pass crossover on the sonys aroun 80hz to 4khz that be about good you think ?
        • Re: sony buyout
          Hi newbie here.
          I am interested in this build. Already have 24 of the Sonys.
          Any progress
          • Re: sony buyout
            Originally posted by bkeane1259 View Post
            I actually like the Vifa BC25SC15-04 that you pointed out. I may do an exchange or just get a pair of those to test with the Sony's.
            Both tweeters go low enough to allow a crossover point that will help tame the nasty 5k hump issue with the Sony drivers. I'm nowhere close to starting my project....but I will be lurking here for info.
            I actually liked this tweeter a bit more:
            http://www.parts-express.com/pe/show...umber=264-1028
            Having heard it, I can vouch for its performance. I prefer it due to ease of flush mounting it over the truncated frame. Significantly easier to create a recess for.
            I'm still waiting on r-carpenter to chime in on his progress with his line array.
            Modding the Lepai T-Amp
            • Re: sony buyout
              At .69 cents a piece these would make some cheap, awsume 300-500 yard varmit rifle targets or 100-150 yards black powder rifle targets or paint the dust caps in the center white and use them for a 100 yard .22 cal target. Use some to make speakers to listen to music while you were shooting the others.
              What an absolutely amazing multipurpose unit. Man,it's been a good day today!
              If I knew what all that technical lingo you guys have been using meant, there would be no end to what all I could do with these. :rolleyes::D
              Hippybilly - Half Hippy, Half Hillbilly - The Best Of Both
              • Re: sony buyout
                That's the tweeter I'm going with too...using 8 of the Sony's.
                • Re: sony buyout
                  Project is a bit on the back burner. I am getting my "Alice" ready for NY/NJ DIY in the end of October. I'll get back on that after. Sorry.
                  http://www.diy-ny.com/
                  • Re: sony buyout
                    Any progress on the open baffle design?
                    I'm building an open baffle design with 12 midwoofers and a single Vifa XT25 tweeter. I completed the baffles today and I should have time tomorrow to install the drivers and begin the crossover. I'll post updates as I test different crossover designs. In the picture that's linked below the new design is the one on the left, not the veneered one on the right
                    http://fredt300b.smugmug.com/Hobbies...712783_LsjgBF6
                    • Re: sony buyout
                      When done, could you compare with the foster OB array you built a few years ago somewhat inspired by a foster/apexjr array I constructed around that time ?
                      • Re: sony buyout
                        The AudioFred Sony FrugalArrays are up and running. As I anticipated, the woofer array's frequency response is very different from the response of a single point source woofer. The comb filter effect in this array begins at about 1khz, and after trying various woofer filters I found they sound best running full range. I'm using a third order crossover on the Vifa Xt25 tweeter.
                        Here's the link to a picture: http://fredt300b.smugmug.com/Hobbies...196823_37hRx64
                        I don't know how to post the frequency response graphs here, but you can see them in this thread at the AudioRoundTable forum. http://audioroundtable.com/forum/ind...16614&start=0&
                        The sound is better than I expected. The midbass is strong enough that they don't sound anemic. The only significant downside I hear is the 3/4" mdf baffle with no bracing is very resonant. If this were a serious project I would use two panels glued together to make a 1.5" baffle.
                        This array sound much better than the 14 woofer Foster array I described in a previous post. I has used a small waveguide with a compression driver, and this tweeter would not respond low enough to integrate with the woofer array, resulting in a hollow sound.
                        • Re: sony buyout
                          Which exact tweeter did you use? Is it this one?
                          http://www.parts-express.com/pe/show...TR=vifa%20dx25
                          I might just do the same when building my own. Could you also provide the crossover diagram for the tweeter? I don't think the Vifa tweeter I mentioned earlier will play as low as the one you used and I really don't have time to design something else right now.
                          • Re: sony buyout
                            First, I love the name -- good job there. I've got a case of these little beauties and have been waiting for someone to "solve the riddle" before I start cutting wood. Are you going to continue developing these, or do you think the project is worth the effort? I may have missed a comment earlier, but at the risk of asking a question the lawyers would argue has been "asked and answered," do you think the open baffle design is the best approach, from an acoustic standpoint? Do the AudioFred Sony Frugal Arrays produce the benefits the open baffle devotees describe, to any significant degree?
                            I'll be following your work with great interest... By the way, can you post the frequency response graphs on your photo hosting site? I couldn't get anything on the AudioRoundTable Forum.
                            Tritrix HT:http://techtalk.parts-express.com/sh...d.php?t=222519
                            Dayton 12" Subwoofer: http://techtalk.parts-express.com/sh...d.php?t=222930
                            Overnight Sensations: http://techtalk.parts-express.com/sh...d.php?t=223751
                            Cerberus sub: http://techtalk.parts-express.com/sh...hlight=cerebus
                            Duellatis: http://techtalk.parts-express.com/sh...d.php?t=224943
                            NTN's: http://techtalk.parts-express.com/sh...d.php?t=227902
                            • Re: sony buyout
                              I think the audioroundtable bitmap images fail to render correctly on some browsers. I "extracted" the images and converted them to pngs. Here they are.
                              Single Driver (1m)
                              Arrayed Drivers (1m)
                              Arrayed Drivers (3m)
