If you have an immediate customer service issue, please email Parts Express at [email protected] or call 800-338-0531, Monday-Friday 8am - 6pm EST.
basic measurements.
I couldn't do distortions and waterfall today because my neighbor was running thickness planer all day. So these will come next week some time.
Calibrated mic as well.
I thought a case was 24 woofers but you said there's 36.
I just thought about the number of layers and realized my error, came scurrying back to make a correction -- but too late. Made the correction anyway. 24 per case, i.e., two layers of 12 is correct.
minimum phase. HBT was done from merged response file.
Sweet!
When can I get a .frd and .zma file to start designing a crossover? I need to order 2 more cases of these, since I'm using one up for the line array and I need more for the TM speakers I'll be designing.
on Monday I guess. My computer is at work.
How do I produce .frd or zma in Sound Easy? Export as.......... I have to look in to that.
So, what do you think, Tank it on the top end and may be that's enough?
Raised response below 200hz worries me a bit.
ringing at 5k is just a cone resonance. I'll look a bit more in to frame improvements after CSDs next week.
Nevermind on the .zma. I just remembered my WT3 can get those files as well. I've uploaded the .zma file I just took from one of these. I had to rename the extension to .txt in order to add it as an attachment, so you'll have to change the file extension in order to use it.
Looks like there may not be a way to export the .frd. However, I might be able to trace one of the response images you posted.
Yep, I looked through that as well. I'm actually in the process of tracing it myself. Any chance you could upload a higher resolution image of the frequency response?
