I picked up a pair of Thiel CS 3.5 cabinets from craigslist for $135. They came with the crossovers, but all of the drivers were parted-out. Also, I just found out that these speakers originally came with an external bass equalizer, which I don't have. (I've emailed the seller but I am not hopeful.)
I need to find appropriate replacement drivers. The Dayton Reference line is looking good and they will fit perfectly in the original holes. The speakers were originally 4 ohm, but I wouldn't mind making them 8 ohm. (Is this ok with the original crossovers?)
I'm looking at:
Woofer: Dayton RS270-8
Mid: Dayton RS125-8 (This is a 5" instead of a 4" like the original, but it fits the hole perfectly.)
Tweeter: Dayton RS28F-4
Are there any concerns about the original crossover (400Hz, 3kHz.) working well with these drivers? If I don't have the equalizer, would there be an issue? Any way around it?
I'm a hobbyist and not a true expert, thanks for any and all advice!
Here are the original specs:
Description: Three-way, sealed-box loudspeaker with line-level bass equalizer.
Drive-units: 1" soft-dome tweeter, 4" paper-cone midrange unit, 10" plastic-cone woofer.
Crossover frequencies: 400Hz, 3kHz.
Frequency response: 20Hz–20kHz ±2dB. Sensitivity: 88dB/W/m.
Nominal impedance: 4 ohms. Minimum amplifier power: 40W.
Dimensions: 41" H by 13" W by 13" D. Weight: 75 lbs each.
Internal volume is about 2085 cubic inches.
I'm looking at:
