Paul Carmody's OS in a (compact) 5.1 config?
Re: Paul Carmody's OS in a (compact) 5.1 config?
welcome here. if you are able to keep the mt upright, it will actually make a very good center channel. you may have to cross rather high from subs, so consider two 8". good luck." To me, the soundstage presentation is more about phase and distortion and less about size. However, when you talk about bass extension, there's no replacement for displacement". Tyger23. 4.2015
Another option is to just lay an OS TM on it's side.
My blackbird center channel is basically an SR71 TM layed on it's side... Changes I did make to it were I made the tweeter and woofer as close together as possible (even cutting into the tweeter flange), and I adjusted the crossover slightly to reduce BSC.
Only downside is visual asymmetry, but I actually like that.... Not even a hint of asymmetrical sound.
Here's a thought: build the 4 TM's first, and experiment with using one of them on it's side as a center. You might be surprised at how good it sounds, particularly since it's such a good match with the mains.
I think the TB W6 will work well for your sub. Try to wait to get the NEW (NON-neo) version of that driver. TB claims the specs are the same? They should be substantially cheaper than the original neo version, but if the specs ARE the same, you could drop it into that design.
chris
I pretty much built what you are considering. Pic is on Paul's website. I later made a OS MTM for the center. Very nice little system. I powered it with a HK AVR154, IIRC. About five hundred for the whole thing at the time. Heed Chris' advice on the Cerberus driver.
Awesome, solid advice guys. Thank you very much. This is exactly what I was looking for. My wife and I are working students, with a three year old. That means money is tight right now, and when we do get time together we're both exhausted to the point of not wanting to do much more than sit and watch a movie.
I'm not complaining as she's a closeted action movie nut. She's seen The Thing, Die Hard, Terminator, etc., etc. and enjoyed them all with me. It'll be nice to move away from the tv's built-in speakers, and while she doesn't see the point right now, I think she'll fall in love with a decent surround system once she hears it. I know I'll appreciate it, in any case. :D
DJG - Thanks for logging your build. It's actually offered a lot of inspiration. May I ask why you ended up switching the center for a mtm?
I shouldn't need to flip a TM as I have a bit of space between the electric fireplace, and tv. I'll probably just build a custom shelf for the center channel.
This system was a gift for my GF's nephew. He has a very bad setup in his bedroom. Before I made the MTM, the center was way down below the TV on a shelf. The MTM went on the top shelf same as the L/R, with the TV on top of it. Much better.
