Micro Sub using ND105 4" driver
  • Micro Sub using ND105 4" driver
    So I keep hearing how the Nano Neos and the NTNs have so much bass. I haven't seen any subwoofer designs with them though. The 4" version actually models better for a sub than the 5.25" version. Well, if you plug a single driver into a ported box calculator, you can get some interesting configurations:
    8 Liters: f3 40.5 Hz
    10 Liters: f3 36.2 Hz
    12 Liters: 33.1 Hz
    Port is 1.5" ID 6-7" long depending on box.
    Perhaps 2 of these (8 ohm) paired with a dayton 70 watt amplifier would be a great little mini-sub. You could make it as narrow as 6" using 1/2" mdf. I don't think these drivers are suited to bandpass use.
    Now this doesn't seem that impressive, but this is before room gain as well. Not sure how to sim 2 drivers. Only real problem is that the neodymium drivers are so expensive right now.
    But why would you do this?
    Well, you could get a 9L box that would be roughly 6 x 9 x 16" that would fit just about anywhere and produce deep (but not loud) bass.
    -Dan
    Mandolin Curved Cabinet Floorstanding; Dayton Reference 18" sealed Subwoofer; Sealed 12" Dayton Reference Subwoofer ; Overnight Sensation builds
    Re: Micro Sub using ND105 4" driver
    Definitely not a bad idea, but how much do you really want to pay just to use that speaker when the 6.5" Buyout sub is $8 (if you buy 4 or more).
    Modding the Lepai T-Amp
      That's true- I forgot about those. I'll have to look for threads on the buyout sub.
      -Dan
        Durango?
        Don't forget, even though the Xmax is 4mm, the Xlim is 10mm.
        When designing, I use 6mm, with a self-imposed 8mm limit.
        Before my Nano Neos (although I didn't know it at the time), TTBOMK there were 2 designs using the ND105-4. MZ's "New Horizons", and there WAS a sub built, just like you'rre suggesting.
        Chris
          I have built a pair of the original neo nanos and I've played some bass test tones through them. They won't go crazy loud, but in an apartment I wouldn't want anything louder. The bass is satisfyingly deep. I think they would make decent subs, and certainly something to talk about when visitors see them.
          I made a small set of mini desktop towers to use as subwoofers for my computer desk, based on Wolf's 'Bass Toaster' design concept. They use TB's 3" drivers, not as nice or deep playing as the Dayton's but they work fine for that application.
          I've thought about buying a set of the ND105's to make a small subwoofer with myself. I think it's a good idea, I hope you do it, and take lots of pics!
          TomZ
            Using 1/2" mdf do you think 5" external width would be doable, or would that "choke" the woofers?" Cutout diameter is 3.625"
            -Dan
              that is 1 liter - what do you think ;)
              Brad
              piano black sealing mdf irregular recesses grill technique
                Yeah, what's the point, I don't think the SA25 will fit in a 5" cube anyhow? You're blowing almost 2 octaves. If you want to jamb something into a 5" cube, get a 3" TB on closeout for $9.
                For sub duty, you want somewhere between 1/4 and 3/8 vented cu.ft. That's still tiny for a sub that reaches down into the 30's.
                Chris
                  When I'm designing an enclosure I usually make the width [driver cutout]+2*[thickness of baffle (up to 0.75")] as a minimum so that you have enough room for the chamfer on the back side. Then I just round up to the nearest 1/4" or so.
                  रेतुर्न तो थे स्रोत
                  return to the source
                  leviathan system thread
                  deadhorse thread
                  shockwave build thread
                  instagram :: greywarden_13
                    Newb question: What's the difference between Xmax and Xlim, actually, what is Xlim, the difference between the two may become apparent just knowing that.
                      Xlim or actually "Xmech" is the mechanical limit of the excursion by the backplate, or the fact the suspension will not allow any further travel- period. Don't run things to that point.
                        Ok, now I do have to ask, how does that differ from Xmax? I thought Xmax was the mechanical limit of the driver.
                          Xmax is the factor of the maximum linear excursion in one direction, which is to the point the Bl product drops by a certain percentage, or mathematically;
                          Overhung; (coil length - gap height)/2
                          Underhung; (gap-height - coil length)/2
                          Usually, it is defined as a one-direction movement, or the added "p-p" for total excursion of both directions.
                            I'm sorry, the "Bl product"?
                              The effect of the motor strength (Bl, usually in Tesla-meters) on the voice coil is lessened the further out of the gap it goes.
                              This is on standard configuration overhung or underhung drivers. Dual-gaps, varying thickness coils kind of get around this point.
