So I have a Sound Blaster X-Fi 5.1 Surround USB driving a Sure 4 channel amp for my sound system/theater, but on older analog CD rips I'm having a problem reaching full volume. I'm sure I'm needing a preamp in between these two, but don't want to break the bank. Any simple fixed gain DIY preamps out there to be hand for low or moderate cost? (I'm thinking sub-200$ but 100$ would be awesome). I'm thinking fixed 10db (or maybe 15db) gain would work perfectly.
DIY Simple Preamp?
DIY Simple Preamp?
Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
Sites: Jupiter Audioworks - Flicker Stream - Proud Member of Midwest Audio ClubTags: None
Re: DIY Simple Preamp?
A couple of options:
TCC TC-780LC
Ocean Matrix OMX-HHLAS"Not a Speaker Designer - Not even on the Internet"
How DIY do you want to go? A simple dual op-amp of your choice (LM833, TLO72, OPA2134, etc) and a few resistors - you are there. Only tricky part is +/- 15V supply. Maybe you can use the supply rails in that Sure amp?
Otherwise, some of the prosound solutions might work for you. ART Cleanbox for example.
Lots of old but great preamps on ebay and audiogon. SS or tube. Rotel, parasound, sony, marantz, and many more.
If you want to DIY, go to www.diyaudio.com and look at the Pass B1 thread, or go to www.passdiy.com. the B1 buffer preamp, same as the First Watt pre that sells for more than 1K, can be made for less than $175 and is a great piece. tho realize it has 0 gain.
Originally posted by engr_dave View PostHow DIY do you want to go? A simple dual op-amp of your choice (LM833, TLO72, OPA2134, etc) and a few resistors - you are there. Only tricky part is +/- 15V supply. Maybe you can use the supply rails in that Sure amp?
Otherwise, some of the prosound solutions might work for you. ART Cleanbox for example.Any chance of find a circuit design online somewhere?
Otherwise that TCC preamp looks like something that fits the bill exactly.
Thanks!Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
Originally posted by JasonP View PostGoing full-on DIY is fine with me,
Being a member of the headphone audiophile group, I recommend a headphone amplifier. All of them can be easily modified to be a simple pre-amp with no volume control and they won't impose their own sound since they all aim to have a neutral sound signature as a primary amp for headphones.
Here is a list of common ones.
http://www.head-fi.org/t/537398/list...one-amplifiers
Surprised no one has mentioned the great Rod Elliot DIY site.
Lots of excellent projects, some simple and HQ preamps:
http://sound.westhost.com/projects-2.htm
Tangband W6-sub
Originally posted by iLovPieNCake View PostI recommend a headphone amplifier.
I'll be offering bare PCBs, completely assembled PCBs, and likely a fully assembled product style version. I knew it.... :D :yes:
Group buy is almost closed, but I think there are some balanced to SE kits left. Should be easy to set up as as SE input too I think.
Originally posted by JasonP View PostGoing full-on DIY is fine with me, I mean, I've built the other parts of the audio chain, whats one more piece?Any chance of find a circuit design online somewhere?
Thanks!
Here's one using a 2N3904
If you have a amply "junk box" of parts to cannibalize - fabrication is very cheap:
However it is often hard to find/buy single "specialty" parts ( without large shipping costs ) and so it often becomes "a labor of love" and not cheaper than buying a fabricated product from a company that has advantages ( like lower parts costs ).
SECARS - The Southeastern CT Amateur Radio Society Find out more Join us on Groups.io by clicking here or send a blank e-mail to [email protected] Announcements SECARS Auction - May 6, 2023 Come to the SECARS Auction to buy or sell amateur radio gear! SECARS will be"Not a Speaker Designer - Not even on the Internet"
Originally posted by JasonP View PostSo I have a Sound Blaster X-Fi 5.1 Surround USB driving a Sure 4 channel amp for my sound system/theater, but on older analog CD rips I'm having a problem reaching full volume. I'm sure I'm needing a preamp in between these two, but don't want to break the bank. Any simple fixed gain DIY preamps out there to be hand for low or moderate cost? (I'm thinking sub-200$ but 100$ would be awesome). I'm thinking fixed 10db (or maybe 15db) gain would work perfectly.
Best investment you will make all you need is a small 12V-0-12V transformer and a DIY case. Very low distortion and plenty of gain plus you can adjust the gain wtih a couple of minor resistor changes. Distortion is .0003%. Will drive any amp to full power and is inexpensive and an easy Saturday morning DIY project.Dave
If you can read this, thank a teacher.
If you are reading it in English thank a Veteran.
Originally posted by dthomas View Posthttp://www.ebay.com/itm/OPA2604-Serv...item336ea77b58
I was thinking about trying that same kit, but I would like to see the design first."I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
