Is sound dampening required for a subwoofer?
  • Is sound dampening required for a subwoofer?
    Say I just built a sub that will cover 20Hz to 60Hz (where it gets crossed over at 18db/oct), does the cabinet need any sound dampening inside or are those frequencies low enough where most standard sound absorbing material become ineffective and will do nothing more than occupy some air space?
    Just curious. The cabinet is vented btw.
    Thanks in advance
    Re: Is sound dampening required for a subwoofer?
    Thanks in advance
    A well braced sub is more important than a well lined sub, but there are other opinions. If your cone generates upper harmonics that could leak out of a large dia. forward facing vent, or telegraph through a paper cone, you could throw a hunk of convoluted foam or glass behind the driver or vent. I've built vented subs w/out any lining that sounded fine.
    Chris
      http://sound.westhost.com/articles/boxstuff.htm
        +1, and all cones generate harmonics, so lining should be used. It won't affect anything within the sub bandwidth, but it will help reduce unwanted above-bandwidth content.
        www.billfitzmaurice.com
          What about sealed?
            A nice article, but irrelevant for the topic at hand.
              Interesting article, but it pertains to satellites, not subs.
              Hopefully the OP won't have any 400-1000 Hz freqs off the back of the cone to worry about.
                Originally posted by lunchmoney View Post
                What about sealed?
                Stuff it. Measure the box Q to see how much is needed. Add stuffing until you get Q below 0.8 or you can't fit more in.
                  Thanks everyone. I decided to try it first without any dampening, then I will add some and see what the difference (if any) I'll notice
                    Yeah that's what I figured, and that's what I did on my dayton ref HF 12 in a 1.8 cu ft sealed.
                    But I didn't measure, I just used the "1lb per cubic foot" method.
                    How would I measure Q?
                      Why, with your trusty Woofer Tester.
                        +1. If you stuff a box that's already got a Q of 0.7 or less you'll make things worse, not better.
                          Meh, that's beyond my ability/willingness to buy more equipment.
                          It sounds great, not going to mess with it.
