Re: Sony buyout project
Yep, i looked at it. Would be interesting to compare head to head because my FR is very similar. The solution is entirely different tho.
Just wait till you start. It usually results in a hair pulling for a first few weeks.:D
The changes would be very small if any. In all probability I'll get a few stock DX25 tweeters and correct the crossover, but that'll be after the new years.
Good news is......................drum roll...............the crossover is done.
Even better news, the speaker sounds awesome. I rarely compliment myself but this $0.69c wanders are singing now. And I mean it, they are sweeeeeet.
Frequency response is leveled within 4db, which is fine considering it's a dipole. Ops, I've changed a 6k notch slightly. Also added another shelving notch to tame raised response below 500hz. Impedance is amp friendly and doesn't drop below 4ohms (mostly about 6-7ohms, 4ohm in the tweeter range).
I am using 100wpch Carver amp. At 90db SPL on the music, the dials are around 3watt. The amp is barely warm. I'll be trying Nelson Pass 15watt class A clone next.
The next step is to take the drivers out, finish the speakers.
I will verify the performance and fine tune things in a next couple of weeks. Of cause squiggles will be posted.
Speaker works fairly flat to 120hz with distortions 40-50db below 200hz to 20khz at 94db spl.
Originally posted by Mayhem13
View Post
Originally posted by Starkiller4299
View Post
Originally posted by XtremeRevolution
View Post
