Re: Budget T-Amp Shootout - Lepai vs. Indeed TA2020
The bigger PS allows you to get more output out of the Lepai amp before it shuts down on its own due to undervoltage or starts clipping. Try a bass heavy track and play that on the Lepai amp for a while. You'll notice the lights start dimming as you crank it louder, then it just shuts off. Doesn't do that with the 5A power supply.
The calculations are simple. The amp is rated for 20W RMS x 2, so 40W RMS. In order to deliver 40W RMS, you need to pull 3.33 amps at 12V. A 2A power supply simply cannot keep up.
What he said.
Looking forward to it. What you really need to do now is compare the modded Lepai to the stock Indeed. Seems like the price difference is pretty small (not including the time needed to modify the Lepai amp), but I'm certain that you'll notice a difference if you haven't yet modded one.
Whereabouts in Chicago are you again? I could let you borrow a Modded Lepai amp to test if you'd like. I have two right now and I don't need to use both of them all of the time.
Originally posted by bkeane1259
View Post
Originally posted by vlad335
View Post
View Post
