Budget T-Amp Shootout - Lepai vs. Indeed TA2020
Re: Budget T-Amp Shootout - Lepai vs. Indeed TA2020
I also measured a Stellar Labs amp from MCM which managed 8 watts. http://www.mcmelectronics.com/produc...0145-/50-10145
I'll surmise that the Tripath amps I measured were ultimately limited by the PS. Looking at the data sheets for the various Tripath chips you will find that some of the chips will take more than 12V. I found that the 12V/4A brick supply that I have would drop to 11.4V with a 3A load and had plenty of ripple which doesn't help. The Indeed amps managed a little more output and I'd attribute that to the fact that they probably used higher quality parts in their output filters. They were much better built than the other amps having quality metal cases and decent input/output connectors. Bottom line is you can't expect a lot of power but they are pretty economical and I find the Stellar Labs amp I have to sound pretty good running my RS Optimus speakers hooked to my computer. I think I got it on sale for $12.
Ron
Ron, did you have any chance to run the Indeed amps from a heavy-duty (say 6amp+) power supply? A "retired" PC supply putting out 11.8-12 volts @greater than 6 amps dead pure DC can be found (around here) for $5 or less minus the IEC cord. They are so "stiff" a supply, the voltage is locked between 0 and 95% rated amperage output or better. Better power supplies make any amplifier sound better (from my Ham radio days). The "best" test of all of these chip amps would be to use a "12 volt" battery regulated to EXACTLY 12 volts DC, but with as much current as possible available (20 amperes at least) to take current/voltage drop out of the test results. There are "hockey puck" voltage regulators for 12 VDC that can handle 60 amps (they need to be mounted on 10mm aluminum plate and water cooled) with extremely high voltage voltage regulation accuracy. For us, a "12 volt" lead-acid freshly charged automotive battery [Optima "Yellow top"] (nominal 14.4 volts) with a string of 30 amp silicon diodes (.7 volt drop each) to bring them down below the "magic threshold voltage" of these amps, I think would be a "better" test protocol. A 20 amp lab supply would be good too, but they aren't common these days and CA-CHING!!! The major improvements in the Lepai's performance with a bigger PS and bigger, better caps indicate the importance of "instantaneous" current demand in amplifiers (I think).
Originally posted by Whitneyville1 View PostRon, did you have any chance to run the Indeed amps from a heavy-duty (say 6amp+) power supply? A "retired" PC supply putting out 11.8-12 volts @greater than 6 amps dead pure DC can be found (around here) for $5 or less minus the IEC cord. They are so "stiff" a supply, the voltage is locked between 0 and 95% rated amperage output or better. Better power supplies make any amplifier sound better (from my Ham radio days). The "best" test of all of these chip amps would be to use a "12 volt" battery regulated to EXACTLY 12 volts DC, but with as much current as possible available (20 amperes at least) to take current/voltage drop out of the test results. There are "hockey puck" voltage regulators for 12 VDC that can handle 60 amps (they need to be mounted on 10mm aluminum plate and water cooled) with extremely high voltage voltage regulation accuracy. For us, a "12 volt" lead-acid freshly charged automotive battery [Optima "Yellow top"] (nominal 14.4 volts) with a string of 30 amp silicon diodes (.7 volt drop each) to bring them down below the "magic threshold voltage" of these amps, I think would be a "better" test protocol. A 20 amp lab supply would be good too, but they aren't common these days and CA-CHING!!! The major improvements in the Lepai's performance with a bigger PS and bigger, better caps indicate the importance of "instantaneous" current demand in amplifiers (I think).
Ron
I understand the voltage limitations, but the current draw (if it is virtually unlimited) I think is far underestimated in these chip amps. Watts in X power factor for the amp => RMS watts output. A pure class A amp may have a power factor of .10 or even less. You put 100 watts into them and you might get 10 watts output (or less). These "T-class" amps are quite efficient, To flatten the FR, they give-up a little pure power. If you can't boost the voltage, I can't help but wonder if more amperage would help.
Ron, this is a most excellent analysis!! :applause:
Thanks so much for taking the time to run the tests/measurements and for sharing the findings with everyone. It's good to see the REAL specs for these amps, especially since they are so popular. Crappy, unreliable, manufacturer specs really confuse people all the time.
Just to be clear though.....for the t-amp measurements, you did both channels driven. So for the Lepai TA2020, when you say 8 watts, that means 8 watts RMS both channels driven, A.K.A. 4 watts per channel RMS? After reading this a few times, that's my only question.
Again, great job man!!Bryan K.
Midwest Audio Club
Speedster | Sub Attaché | The Wildeman | Sean's NLA Towers | COÜGAR, COUGAR II and COÜGAR JR | Triton | Lithium | J-Boom | Trym MLTL | Docere MLTL
Ron
Originally posted by Whitneyville1 View PostI understand the voltage limitations, but the current draw (if it is virtually unlimited) I think is far underestimated in these chip amps. Watts in X power factor for the amp => RMS watts output. A pure class A amp may have a power factor of .10 or even less. You put 100 watts into them and you might get 10 watts output (or less). These "T-class" amps are quite efficient, To flatten the FR, they give-up a little pure power. If you can't boost the voltage, I can't help but wonder if more amperage would help.
These amps gain their efficiency because they're switching amps and the output transistors are mostly all the way on or all the way off all the time. In either state there's little power dissipated in the transistor. If it's on there very little resistance in the transistor and if it's off there's no current flowing through it. Class A amplifiers have the output transistors biased half way on all the time so there's lots of power dissipated all the time even with no signal.
Ron
Originally posted by Ron_E View PostWhen I say both channels driven I mean that both channels had the same signal and load applied to both channels while the measurements were made. That means that in the example you gave the Lapai is capable of 8 watts RMS from each channel with a 4 ohm load. I don't have two 8 ohm load resistors but I did measure one of the amps with 1 channel running into 8 ohms and measured the same voltage which would be half the power.
Ron
They are all great value amps for sure.Bryan K.
Midwest Audio Club
Originally posted by Ron_E View PostBrian was kind enough to loan me his collection of amps so I could take some power measurements.
."Our Nation’s interests are best served by fostering a peaceful global system comprised
Great info! Thank you all for taking the time. It just blows my mind that my little SMSL TA2020 is only putting out 8 or 9 watts and still fills a room with sound. I'm using it to run some OS TMs which are not highly sensitive but yet it has no problem playing beyond comfortable hearing levels. Makes me rethink the whole watts thing and how much you actually need.
