I need some advice from the speaker design gurus out there. If you are willing to help out a amateur builder I would be grateful for some advice.
A little background:
I'm planning to build a pair of Curt's Stentorians in the Spring. These are a gift for a friend that hosts band parties regularly at our Church Parish House. He has been using his own semi-pro speakers, but the kids have already blown the woofers in his gear once. From the description of the Stentorians on Curt's web site these seem like the perfect replacements. They get really loud, and if they do manage to blow a woofer it will be a lot cheaper to replace a woofer or two in the Stentorians than in my friend's gear.
I have built a few of Curt's designs, so I know this design would sound great if I built it to spec. The problem is I don't want to build it to spec.
While reading through some build threads, I saw Passing Interest's Howitzer Build and was blown away by his build. I just loved the way the baffle looked and wanted to build something similar. I had already picked the Stentorians as my next project, so I spent a little time in Sketch-up and came up with this:
Basically my plan is to use the baffle dimensions from the Stentorians (with rounded tops), flush mounting the drivers per the instructions, but then attach that 3/4" thick baffle to a second wider baffle to produce the same effect Passing Interest got with his baffle cover on the Howitzers. The problem is that this changes the baffle in ways that I know will impact the sound. I don't know enough about speaker designs to anticipate how much the sound will change or figure out how to update the crossover to compensate.
I know this baffle is "wrong" and that the best way to build the baffle would be to spec with a single large round-over, but this is the look I want. The question is will this baffle shape cause a noticeable change in these speakers? I can't measure and update the crossover (way over my skill level), so if this is likely to need that sort of update I'll just build them as Curt designed them. But if the difference in sound with this baffle would be unnoticeable, I would really like to try building it.
So what say you, is this design a go or a no-go?
