Hi Lou:
I was going to send this as a PM, but I figured maybe I'm not the only one jealous of your work. Either you are very good at taking forgiving photos OR you produce a lot of consistent results. I'm thinking it's the latter.
First off, do you shoot all of your cabinets, or do you occasionally hand-apply the finishes? I'm beginning to think that if I ever want a clean finish devoid of imperfections that I might as well give up on using brushes. I can occasionally do okay with an oil-based polyeurathane, but anything else? Forget it.
Secondly, do you cut all the driver recesses AFTER veneer is applied? Does this ever lead to extensive swearing and scrapped cabinets? I routed my first holes in a veneered cabinet recently. It was just for a port tube on the back, so I was feeling sassy and gave it a try. The end result was shockingly clean! However, I also know that the front baffle is where I commit most of my enclosure mistakes, so...
What's your preferred veneer backer? Paper, NBL/2-ply? If paper, is there a particular way you cut & assemble the cabinets to limit telegraphing?
Thanks for any advice. There's no doubt you're an inspiration to a lot of your fellow builders.
Regards,
Dirk
Regards,
Dirk
