So sorry I missed your post/questions. Life you know... Making my way back to the speaker world... like a warm blanket.
I surmise you have already decided on how you are proceeding, but I will chime in anyways
djg is correct, do not worry about the baffle thickness here.
Regarding sub crossover, I'm doing 75hz.
If you click on ck moore's name, you'll see he hasn't logged in here since April. He might visit without logging in, I'm sure 3/4" is fine, keep the same volume.
You might need to relieve the back side of the baffle to allow better airflow.
I’m looking at this build as a potential solution for my home theatre, since it seems to tick all the boxes:
Goes low enough to allow an 80Hz (or slightly lower) crossover to a subwoofer.
Close to wall mounting (so the surrounds and backs don’t sit in the walkway through the home theatre area)—this shoots down any rear ported and transmission line designs.
All the parts are still available (this shot down the AviaTrix I was looking at—but the low back to front profile of these is probably a better idea anyway).
… the baffle is a solid piece of 3/4 walnut... I think it actually measures closer to 7/8".
The plans you have on your picassa show a ½″ thick baffle, but the baffle you used was some ¾″–⅞″. Does this make a difference? I have easy access to 19mm thick Tasmanian Oak, but in the width needed I can’t get it in 12mm, so a ¾″ baffle would be much easier.
I realize this thread is ancient...Have a crossover question. Are the B3N mids and tweet hooked up in reverse polarity, with the B4N's normal polarity?
Hi, sorry to bump and old thread, but how would these compare to the Overnight Sensations MTM? I have a set with the center channel and I was thinking of scraping the center and using the B3N's from it in the mains to make these. It would cost about $50 each for the crossovers and new tweeters (I used the HiVi ones in my OS's).
Do you think it's worth $50 each or should I just keep the Overnight Sensations? They will be in the bedroom, 2.0 system. Maybe eventually a 2.1 using the Voxel sub.
Sorry, no graphs or measurements. I haven't ventured into that phase of speaker design yet...
And they are listened to everyday. Very happy. As for impressions, they are 99% percent HT usage. And sound better than my local theater. I really haven't done any isolated critical listening to come up with cool audio buzzwords. All I can say, is they really sound like a much larger soundstage version of the Overnight Sensations. There are tons of threads with listening impressions of those. Although I do think the highs are better more precise and crisp on the these than the Sensations, with the slightly different tweeter. Paul helped me tweak the padding on those, since they were were a bit hot initially.
As for changes if doing them again? I would not use hurricane nuts. Don't do it. And I would not have used such large wire on my crossovers. Live and learn
thank you for coming back to this thread to answer my questions. I am not even an a noob audiophile so i am not interested in buzzwords, and could not even begin to pretend to understand what all the graphs and raw data means around here. I know I have heard speakers, IMO, that have sounded good and bad, and what I like. I also know my situation limits a lot of what I can do for LCR speakers, so I will take what i can get so to speak
Love the way they look... very well done! Do you have a larger TV now?
Here is link to my full build pic library. Hanging pics, they are old, since I have a different tv. But you get the idea. TV is a 2006 48" plasma.
Updated link
This looks like the perfect solution for a shallow on-wall build. Any pictures of them wall mounted? Listening impressions now that you've had them for a couple year?
Nice build! I really like the os mtm's a lot but I like a lot of bass so this would be the ticket. I wonder what Paul's larger version referred to on the first thread is going to be?
Also, I learned this trick from Kanemack but if you use a scrap piece underneath your baffle (1/2" or 3/4") you can use a 1/8" inch drill bit (the same size as the dowel/pin for the router circle jig) drill through the center hole through both until the drill bit sticks out enough to fit into the circle jig, unscrew it from the drill leaving it in both the baffle center hole and the large scrap piece under it. Secure the baffle to the scrap piece with clamps so it can't move. Now when you make your holes you wont ever that that point when the circle moved at the last 1/8" of the cut and if you mess up the jig / center point cannot move because the drill bit is still stuck in the scrap board underneath it. you can just keep using this scrap board for all your future builds.
It's a super easy thing to do and it's better then the pin that comes with the jig because it's got a lot more length so it protrudes into the wood and your router better.
I know it's too late for you but hopefully someone else will read this and use it as well!
