Building a crossover and not sure where to start
Re: Building a crossover and not sure where to start
Well the easiest way to do this really, is going to be this:
Read the Speakerbuilding Bible in the Sticky Section. Then Go to Paul Carmody's website and read his simulation walkthrough.
Go to Zaph's website - Zaphaudio.com - and find those 3 drivers (I'm pretty sure he's measured them all - if not, the tweeter is the only one) and download SPL Copy.
Now trace all graphs.
Now run them through Response Modeler
Now Import them into PCD
When you've done all that, create a thread where you post the living crap out of your simulation pictures and a couple weeks later you will have streamlined the crossover enough, without measuring to build it.
Then you'll build the crossover. And voice it, and change it a couple times. Then give it one final build.
And Voila! You're done.
रेतुर्न तो थे स्रोत
return to the source
leviathan system thread
deadhorse thread
shockwave build thread
instagram :: greywarden_13
As greywarden is trying to tell you, designing a 3-way crossover for a newbie is a monumental task. Unless someone is willing to step in and do the simulation for you, you are facing a long (and probably disappointing) road. What are you unhappy about the speaker currently sounds? You may be able to improve things by adding zobels to the woofer and midrange to even out the impedance and let the crossover work better, and then adding L-pads to even out the levels from the drivers. Will that be equal to a properly simulated and designed crossover? No! But who knows, you may be happy with the improvements.
Originally posted by greywarden View PostWell the easiest way to do this really, is going to be this:
Seriously though, that's a nice little summary.
रेतुर्न तो थे स्रोत
deadhorse thread
Originally posted by greywarden View PostI really, really can't tell you how many times I've typed that. I've probably dumped $700 into the rediculous project I've working on for the past 15-16 months. I should have started with either A) someone else's designs or B) purchasing measurement equipment and using measurements.
Seriously, you know what you're talking about, and you now have a couple of boxes of crossover parts - those will come in handy. Don't be like me, though, and have a shelf full of $5 buyout drivers that you will probably never use. :eek:
Strongly advise a measuring setup. Sims only get you so far. Sometimes they work out great, but other times there are "troubling" peaks and valleys in the measured response that weren't there in the sim.
Tangband W6-sub
Originally posted by JimHRB View PostAs greywarden is trying to tell you, designing a 3-way crossover for a newbie is a monumental task. Unless someone is willing to step in and do the simulation for you, you are facing a long (and probably disappointing) road. What are you unhappy about the speaker currently sounds? You may be able to improve things by adding zobels to the woofer and midrange to even out the impedance and let the crossover work better, and then adding L-pads to even out the levels from the drivers. Will that be equal to a properly simulated and designed crossover? No! But who knows, you may be happy with the improvements.
Originally posted by Chris Roemer View PostRight now you must have some screamin' machine there. I'm working on a 17 element XO right now. Had to cut both the tweeter and the mid by over 12dB.
I'll be back.
Chris
Originally posted by bre's dad View PostPE does have a crossover that would work but I really don't want to spend $100 (about $50 each) if I don't have to. Plus that one crosses the woofer too low @ 375 Hz. I haven't found a premade 3 way XO that has the cross over poiints I'm looking for. I also already have L-pads on the tweeter & midrange.Isn't it about time we started answering rhetorical questions?
Twitter: @undefinition1
Originally posted by Chris Roemer View PostI don't suppose you'd care to push your mid up to touch the tweeter? There's no good reason to put it so far away (and a lot of bad ones).
Chris, If you do not mind, how are you simming the triangular baffle of the OP's original box? I really have to hunker down and learn "The Edge." Or buy Omnimic and learn to measure.
Originally posted by morris View PostThis should be easy enough for the OP to do. Just slap a fresh baffle on top of the old one and cut out new holes. It would be an opportunity to dress is up more if needed.
Chris
Originally posted by Chris Roemer View PostI won't be. I'm only taking him 80% of the way from "textbook" to "as nearly perfect a sim as you can get". I AM shaping the rolloffs properly using real F/Z files, and the phase probably won't be perfect, but like I said, with a stock XO, the tweeter and mid were probably at least +12dB, which isn't really very good. If he had an "F" (or D-) XO, he can have maybe a "B" (or B+). Looks like about 4-5 dB of generic BSC.
Chris
You are very generous Mr. Roemer Sir!
