If you have an immediate customer service issue, please email Parts Express at [email protected] or call 800-338-0531, Monday-Friday 8am - 5pm EST.
on the gating part you should mention to uncheck measurement signal box. all the other buttons are pretty obvious as to what they do. Great start to a easy to use and read guide
Need to add a quick discussion on (or link to) measurement tips and how they effect the measurements and subsequent use in PCD or other software.
I'm still learning but something like...
Show curves measured at high and low volume to illustrate background noise level in room. Is 20dB above background enough? Perhaps not. Do you need 80dB? I don't think so.
Wear ear muffs. You need them for woodworking anyway.
Locate driver mid-way between floor and ceiling to minimize floor/ceiling bounce. Locate away from boundaries to minimize early reflections. Illustrate with curves from good and bad examples?
How to measure low frequency....mic at driver? Ground plane? Need to splice into full-range measurements.
Use consistent amp level (and input recording levels) when measuring a driver set. Tips for getting same level from analog level control (use reference driver/distance and adjust to same measured output?). Don't forget to defeat tone controls, DSP, subwoofer, and other active speaker channels. Flat is where it is at.
Use consistent mic and driver locations to get repeatable measurements. Measure mic location (horizontal and vertical) and driver locations to get horizontal and vertical offsets for use in PCD.
You new about needing a PC right? :D Just kidding around of course. Edited the first post.
I did suspect that, I just need to find one that works consistently. If I have a mic(Shure PG48) and external sound card(Creative X-Fi) that work well together, will a mic preamp still be necessary? Or, does it need to be an OmniMic or something similar and a mic preamp
Some mics may not need a preamp. I don't know for sure. Most will need one. If the mic works with the PC already, then you probably don't need to add one.
The tough thing to fix with soundcards is turning off ALL the special effects. I tried several cards that were unusable.
