Originally posted by johnnyrichards
View Post
$3 1" dome tweeter.
Re: $3 1" dome tweeter.
Originally posted by johnnyrichards View PostConsidering the limited room to work with, Dave, do you have any recommendations for something to stick behind that dome?
I am not over concerned about it, it is just academic curiosity
One thing I would try, because I have it, is some cotton I removed from an old printer years ago. Cotton has been used at times to damp vibrations in some of them. I wouldn't spend any real money on this unless you just want to experiment. I've done that a lot and have a lot of tweeter parts lying all around on my shelves. :eek:
dlr
Interesting thread guys. I have only taken one tweeter apart, a Dynaudio D-28/2 that I bought back in 1992. It was constructed exactly as dlr descibed the SS tweeters. It had a medium density cotton plug right behind the silk dome (with the same profile as the dome), a vented pole piece and a rear chamber that was stuffed with yellow fiberglass. It also had ferrofluid.
Originally posted by johnnyrichards View PostFerro-fluid in the gap makes drilling an even riskier venture. I have some felt furniture feet that I planned on trying.
What you'll need to be very careful about is trimming the edges to ensure that there is no contact with the dome.
dlr
Cabrini MKII uses a different woofer. I have a design using the MCM woofer and the MCM tweeter, just gotta get the info together in one place.
Yes, very nice midrange out of this $5 woofer, though.
Originally posted by johnnyrichards View PostBiscuit - I have a design close to ready using those MCM drivers. We should compare notes
The mids in these are very clear on vocals, and I'd like to try a 3-way tower with the 6.5 pulling midrange duty. Standout vocals I noticed were Norah Jones, Janiva Magness, Diana Krall, Alison Krauss, Kathleen Edwards, Warren Zevon, and Johnny Cash. Good rockin' thump listening to John Fogerty's "Blue Moon Swamp", Collective Soul's "Youth", The Refreshments' "Fizzy Fuzzy Big and Buzzy", Mike Ness's "Cheating at Solitaire", and a little Jackson Brown, "Redneck Friend".
Norah Jones in particular sounded "in the room" with me. (A happy thought!)
Since I knew I'd be running these with a passive sub, I thought I'd see how small a box would still remain practical. I modeled in BassBox6 and came up with a box 6x12x8, for a whopping .33 cu.ft.! This models an f3 of about 75 and f10 of around 45. They are very listenable, even without the sub, at low levels. As configured, should cross easily at 80Hz to any sub.
I've been looking at your Cabrini MKII XO, and comparing it to mine. Mine is way different! ( i.e. amateurish) I was working with a limited amount of material and budget, and you know- "when the only tool you have is a hammer, all problems begin to look like nails." But they are listenable, not bad at all!
Originally posted by Zach C. View PostBummer. It would be hard to justify taking a drill press to it even it it wouldn't be too difficult. Maybe one of those self adhesive felt pads for chair legs would help?
All of the cheap tweeters I've taken apart had something behind the dome. Even an AR 2" dome mid, which had a dome shaped wooden slug glued to the pole.
Thanks for looking in to that.
Zach
Originally posted by johnnyrichards View PostIt appears rear chamber mods will be more trouble than it is worth, however - there does appear to be hope for possibly throwing a small wad of polyfil or something directly behind the dome as there is currently nothing there, and many of the tweeters I took apart seem to have something behind the dome.
Zach
This may sound gross, I've wondered if lint from the lint trap of a drier would make a difference.
It's not what I had thought, I figured that there was at least a pole-piece vent opening. The distance from dome tip to top plate must be close to 1/2".
A soft wad of cotton won't be nearly enough. That one is much like many (very) old tweeters. The better ones had a hard cotton near-hemispherically shaped piece glued to the top plate that left a small gap between that dome and the diaphragm. This eliminates most of the lower and mid frequency resonances and is somewhat absorptive of higher ones. It's not ideal, but with a solid top plate there's not much else you could do. Some of them also had a foam dome rather than hard cotton, but that's much less effective, especially at lower frequencies.
Interestingly, drivers like the Scan-Speak 9300, 9500 and 9700 all have a hard cotton (?) plug over a real vent to a real chamber and the top part is shaped to somewhat match the shape of the dome. This still allows for low end output due to the much larger effective volume.
Whatever you may try, be very sure that nothing can get into the voice coil gap and size it to prevent any dome contact.
dlr
The faceplate is a separate piece of plastic that is very easily removable. Beneath that is a secondary piece of plastic removable by taking out four screws. That holds the VC assembly in place.
Removing the VC assembly exposes a a solid slug:
Originally posted by Zach C. View PostJohnny,
Does it look like these can be opened up for mods?
Pics sure don't look like it. If I ever ordered from mcm, I'd just give it a try, but I couldn't tell you the last time I needed anything from them.
Johnny,
