Driver Size, Off-Axis
Re: Driver Size, Off-Axis
It's hard to put an exact number on it, it depends on cone diameter, cone profile, etc, but it's not important to be ultra precise and there's a ROF which states that beaming will start to occur at roughly 13550 / cone diameter (inches).
PCD will visually show you the estimated off axis behavior.Don't even try
to sort out the lies
it's worse to try to understand.
PCD requires Office.
13550/6.5 = 2,084
Correct?
I guess other factors play a big role, because this guy is -5dB @ 1,500........
http://www.parts-express.com/pe/psho...4-1146&scqty=2An apostrophe with an "s" does not mean plural.
Speaker's IS NOT PLURAL.
Originally posted by icor1031 View PostHow do I calculate how a driver should respond off-axis?
page 264 has the formulas"Not a Speaker Designer - Not even on the Internet"
Thanks, impressive.
Also,
This book uses -6dB.
Isn't that way too low? Shouldn't it be -3 at most?
Originally posted by Sydney View PostUse Google books to get to Sound System Engineering by Don Davis, Eugene Patronis
page 264 has the formulasAn apostrophe with an "s" does not mean plural.
Originally posted by icor1031 View PostThanks, impressive.
Also,
Isn't that way too low? Shouldn't it be -3 at most?"Not a Speaker Designer - Not even on the Internet"
Yeah, best to listen to Sydney, apparently I'm not thinking clearly this evening and I gave you the wrong ROF. Since getting to page 264 on my slow dial up isn't going to happen in this lifetime and I can't even download the driver spec sheet at the moment I did a quick search for beaming start frequency.
On this forum they frequently use the formula 11500 / driver diameter (inches).
In other places on this forum and around the web it's stated as 1/2 (or 1) wavelength. (The formula I gave describes 1 wavelength.)
But I suspect (and PCD seems to back this up) that the on axis response starts to diverge from off axis at around 500 hz or so, which is ~1/4 wavelength of a 6.5.Don't even try
As mentioned ( in post 2 ) it is difficult to come up with an exact figure, because the theoretical calculations are based upon a flat piston, which a speaker cone isn't. A particular cone may be designed to affect dispersion.
Additional discussion:
page 13 - 16 of Loudspeaker and Headphone Book by John Borwick
page 64 of Electroacostical Reference Data by John Eargle
Note what happens when Ka > 1"Not a Speaker Designer - Not even on the Internet"
Here's a visual answer to your question...
Looking at the plots, clearly when the driver is asked to reproduce wavelengths significantly longer than it's diameter, it does so very well... with wide dispersion.
The dispersion gets much worse as the wavelengths approach the diameter of the driver.
Anyway, PCD shows response is -3 db at 80 degrees at approximately 1500 hz for an actual measured cone diameter of 5.5 inches (which should be ~accurate for a 6.5 inch driver.
(I should know this stuff better by now, I just had a very similar conversation a couple of months ago.)Don't even try
That is a lovely graph... It also makes me want to redo my project, but I don't want to build a 4-way.. lol..
Originally posted by ReissM View PostHere's a visual answer to your question...
[ATTACH]22161[/ATTACH]
The dispersion gets much worse as the wavelengths approach the diameter of the driver.An apostrophe with an "s" does not mean plural.
Thanks, mate.
Originally posted by diy speaker guy View PostAnyway, PCD shows response is -3 db at 80 degrees at approximately 1500 hz for an actual measured cone diameter of 5.5 inches (which should be ~accurate for a 6.5 inch driver.
(I should know this stuff better by now, I just had a very similar conversation a couple of months ago.)An apostrophe with an "s" does not mean plural.
Check out the directivity graphs on that SEOS-12 and a B&C DE250, they're pretty darn good. I think I might build 7 speakers for HT with them.
रेतुर्न तो थे स्रोत
return to the source
leviathan system thread
deadhorse thread
shockwave build thread
instagram :: greywarden_13
