So, here's the deal....
Some time ago (5 years), I built a speaker using the Seas CA21 (later the P21), a Neo8, and a Neo3 - in a box.
http://www.htguide.com/forum/showthread.php4?t=26798
I love the way it sounds, and up until lately, it was the speaker I liked the most. But I just fixed my ZDT project, using what I've been able to learn from all of you (
) regarding an uniform power response, and I definitely like them quite a bit more than the Neo based speaker now.
So, it's time to unscrew the old Neos and build something new!
The Neo3 doesn't have a back cup anymore (I built a bigger chamber for it), and the Neo8 is a dipolar driver OOTB. So they are both ready to rock.
I read on the other thread that a pair of RS225s on an H frame may be enough for the low end. Frankly, I'm not going for an SPL record here, but I desperately want to try a dipole / OB.
So I guess this is the ticket. 2xRS225s, Neo8, Neo3. Hybrid design - using the MiniDSP for EQ and the x-over between the RS's and the Neo8 / Neo3, an d a passive network between those two.
It could work. I used the Neo8 down to 800 Hz, L-R 4th order. I'm not sure I'd take it any lower free air. The RS225's can get to 800 Hz, 4th order. The MiniDSP can filter out all the resonances. I already found out 2.8 KHz between the Neos works pretty well.
Unfortunately, I don't have a clue about how to do an OB. It should be simpler than a box, but simulations all tell me it really isn't. My biggest concern is the bass - what's an H frame? I have a clue, but that's not enough. How can I design it?
How wide should I build the baffle?
What can I expect out of it?
Any help will be greatly appreciated... for sure!
